Tech myths
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Tech myths
    LOML wanted to house her Canon 1100 in an old cell-phone jacket which has magnets in it's flaps to keep them closed. I thought the magnets might damage the SD card, but googled for confirmation.
    Happily, this article busts that and other myths. Nice to know.
    - Aristotle
  • germdoc
    • 3567
    • Omaha, NE
    • BT3000--the gray ghost
    That was so interesting I wanted to post it on this site. Then I remembered where I found the link...
    Jeff
    • Bigbit
      • Aug 2007
      • 102
      • Southern California
      Interesting read - thanks for the link.
      • Copper
        • 343
        • Madison, WI.
        Thanks! That was interesting. The article doesn't mention that Microdrives are still susceptible to magnets (Microdrives fit into CF card slots) since they are based on a magnet-based hard drive, AFAIK.
        - Dennis
        "If your mind goes blank, don't forget to turn off the sound." --Red Green
        and yes, it's a potato.
        • catta12
          • Jan 2008
          • 250
          • Reno, NV
          • BTS20R
          Thanks for the tech bust!
          If you can read this you assembled wrong.
          Alan
            • 22109
            magnetic susceptability of various storage media:
            Floppy - yes
            hard Disk Drive-yes
            microdrive- yes
            VHS tapes-yes
            8mm cassettes-yes
            Compact audio cassette-yes
            CD-no
            DVD-no
            CD-R/RW-no
            DVD-R/RW-no
            USB Thumb-Flash Drive-no
            SD, CF, XD, memory Stick (and micro-variants)-no
            cards used in most cell phone and or cameras-no
            iPod- depends on the type, Ipod Nano- no; 20-30 and 60G and video IPods, Yes
            • radhak
              • 3061
              • Miramar, FL
              Floppy - yes
              hard Disk Drive-yes
              microdrive- yes
              VHS tapes-yes
              8mm cassettes-yes
              CD-no
              DVD-no
              CD-R/RW-no
              DVD-R/RW-no
              According to the article, even Hard Disk Drives are not susceptible to magnets, at least not easily. Would need a real large one, not found with regular folks.
              - Aristotle
              • cbrown
                • 127
                • Massachusetts
                Floppy - yes
                hard Disk Drive-yes
                microdrive- yes
                VHS tapes-yes
                8mm cassettes-yes
                CD-no
                DVD-no
                CD-R/RW-no
                DVD-R/RW-no
                Magnetic core memory - yes. Also, be careful not to jar or shake it.
                • BobSch
                  • 4385
                  And when was the last time you ran across any of those?
                  As far as hard drives are concerned — Yes, they are a magnetic media, but the housing acts as a shield so it would take a huge magnet to affect them.
                  Bob
                  • JSUPreston
                    • 1189
                    • Montgomery, AL.
                    I work for the government...any more questions?
                    I'm here all week, try the veal!
                    • jonmulzer
                      • Dec 2007
                      • 946
                      • Indianapolis, IN
                      I could certainly be wrong, since I have never even seen Magnetic core memory, but it is my understanding that core memory was chosen for early military computers because of their resistance to magnetic fields and EMP. They also used the read-only core rope memory for the Apollo missions for this reason. But hey, I have never even seen it, so I have for sure not used a computer that uses it and I certainly don't understand all the intricacies of it.
                        Wikipedia says that core memory is unaffected by EMP, I guess that means it is not affected by a magnet.
                          • 22109
                          EMP is electromagnetic pulse, an intense elecrtical field caused by nuclear explosions. The mot significant part is the electrical field which will damage most solid state electronics. While Core memory may survive (and survival is 2 parts - contents and operability), the electronics sense amps that read the memory will not survive (unless they use vacuum tubes).
                          • cbrown
                            • 127
                            • Massachusetts
                            I haven't seen working magnetic core memory--only boards kept as artifacts in the recesses of the computer room--but it does look as if the folklore I heard about its vulnerability to physical shock and magnetism was inaccurate.
                            Extra credit to anyone who can put together a USB interface to make a 1K magnetic core flash drive.
                            Chris
                              • 22109
                              the funny thing about core memory is when you read it you destroy it. That is, that the memory content is destroyed. However, being only 1 and 0 basically that meant it got flipped. So after your read it, you had to read it again or write it to set it back the way it was.
