the same one ten times! Boy do I feel like a dufus!. I was making some shelf brackets so I figured a template for routering would be a good idea. Even better would be to locate the pilot holes. Or would have been if I didn't locate two pilot holes half an inch too low. And had I realized this mistake before drilling the brackets I would not have been pluging holes with 3/16 dowel this afternoon. Oh well, learn from my mistakes.
Multiple Mistakes Or....
http://richardspensandthings.blogspot.com/Tags: None -
tem·plate also tem·plet (t
m
pl
t)
n. 1. A pattern or gauge, such as a thin wood or metal plate with a cut pattern, used as a guide in in woodworking for replicating mistakes rapidly, repeatedly and efficiently.Last edited by LCHIEN; 01-11-2009, 02:37 AM.
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
A template is a $5 word. How 'bout a simple pencil and paper sketch? You might just catch the error before making that "template".
.Comment
Not always. On the kitchen bench project I made a plan (one of the very few I've done) and carried a measurement error all the way through the project.David
http://richardspensandthings.blogspot.com/Comment
LCHIEN
