maybe a great idea, what do you think
    • 22098
    this suggestion comes up every year or 6 months.
    The answer is always the same, as someome mentioned its a current issue.
    Batteries can put out low voltage and lots of amps.
    AC is practically limited to 15 amps, 1800 w
    if you have a cordless tool it has a low voltage motor, 9, 12, 18V typically
    Corded tools have 120V AC motors.
    A quick survey of corded drill on amazon shows 6, 7, and 8 amp drills.
    So around 850 watts on average.
    For a 12V cordless drill, it would take 70Amps to reach that power level for similar torque. Batteries can deliver that kind of current, and the wire losses are small due to the wire length being just a few inches.
    Now your typical charger, even the fast ones, only put out about 1-2 amps. Its designed to charge continuoulsy for 1,3, or 15 hours to put a full charge in. You can deplete a full charge in a few minutes of high torque work. So a charger would not handle the running current of 70 Amps that might be requred. So a power supply of approximately 30-40 times as much current as the charger is required to meet the peak demands with a low voltage motor.
    The power supply or AC/DC voltage converter would have to be 1) a big brick connected by a DC carrying wire to the drill or 2) be physically plugged into the drill battery connector and have an AC cord going to the wall.
    if 1) the wire to the drill must carry up to 70 Amps. and be real big and heavy or risk losing a significant amount of power. A resistance loss of 1 V to AC motors is only 1% but the same loss of 1V to a 12V motor is almost 10%. So its a double hit on wire requirements- the lower voltage loss needed and higher current, we'll need a pair of 1/0 welding cable (1/0 is a gauge about 100 times more cross section than 16 ga, the conductor with no insulation is 3/8" dia) to power this thing for a distance of 6 feet from the brick to the drill. Of course from the brick to the wall can be 16 ga power cord.
    If 2) then we need a 12V 70Amp power supply in the drill battery socket This would be heavy and inconvenient. Those bricks you have for many electronics devices, laptops, etc now run about 50-100 watts. So scale it up 10 times. It'll be much bigger and heavier than the battery pack it replaces.
    For either solution, the cost would also be high, 12V 70A supplies are expensive. and for 1) the cord would be unweildy.
    We could solve the problem by running the drill off of higher voltages, like 120VDC, then the currents would be reasonable and the wire sizes much smaller. The shock would then be the 120V battery pack for the cordless mode.
    Finally, we could just make a wimpy AC/DC power supply, like 10A at 12V and sell it at a reasonable cost, people would plug it in and be happy it the drill turned. It would work for very light jobs. But when they really tried to drive heavy loads the thing would just hum and stall the motor and possibly burn it up, there's not enough current. Any one you can point to for sale is going to be this way. Not destined for much success.
    So it won't work. I've listed the technical issues. If someone knew how to get around them, they'd be selling these things.
    The only thing that might work is a hybrid system where a corded pack replacement would have a small battery to provide high current for momentary loads with an integral charger for charging the battery continuously (something like a hybrid car in principle) but I think it would futz out on you quickly if doing a bunch of high torque work... a 5% duty cycle would be unacceptable.
    • gsmittle
      • 2793
      • St. Louis, MO, USA.
      Originally posted by germdoc
      I knew I shoulda stayed awake during high school physics when we got to the electrical section.
      My knowledge of elecricity, sadly, extends to plug it in and see if it works, don't mix up the positive (red) with the negative (black) wires, and make sure that line ain't live before you go messing with it. Anything more complicated I'm out of my element.
      Don't forget this one: Don't put wires in your mouth!
      g.
      Smit
      "Be excellent to each other."
      Bill & Ted
        And don't test the charge on your 18v-36v batteries with the tip of your tongue...
        • BobSch
          • 4385
          Kinda like relieving yourself on an electric fence.
          Bob
          • niki
            • 566
            • Poland
            • EB PK255
            As I told you, Cabinetman "knows" everything and he even knew that I connected my drills to an external battery so, be careful with what you are saying in front of him so, he PM'ed me about this post...
            I'm using a 12V-5AH Sealed Lead-Acid battery used for toys or motorcycles.
            I even use the 12V on drills that where originally 4.8V and it works (with higher speed and torque) already more than 10 years.
            I connected the battery also to a 9.6V jig saw and it works better than the original.
            When I'm in the garage, I connect the drills to a step-down transformer rectifier that can supply 12V up to 300W (25A)...I measured the power consumption with locked shaft and got 7~8 Amp (same as they do on the shop vacs to get "6.5 peak HP" ).
            I think that any transformer that can supply 10A (120W) will do the job...
            Regards
            niki
            • pierhogunn
              • 1567
              • Harrisburg, NC, USA.
              Niki, you weren't the kid in high-school that would have built a nuke if you could just gotten hold of enough raw materials were you?
              WOW
              and loring, thanks for setting me straight, I spose I need to have greater respect for how much juice is in my power tool batteries
              bring on the room temperature super conductors, cause I figure that is the only way to get those sort of currents into wires of any length that are reasonably sized
              Monty Python's Flying Circus
              Dan in Harrisburg, NC
              • wan2fly
                • Mar 2007
                • 31
                • San Francisco Bay area
                a field version
                I have a nice Porter Cable 12v 1/2" chuck cordless.
                The batteries have faded over time.
                I sacrificed one battery pack by taking out the cells and hooking up what is essentially jumper cables. I can install my regular battery pack (which I replaced the cells) or I can use my "Jumper" pack and hook it to a car battery. It makes a fairly handy field drill. And a car battery can supply all the current I could draw.
                A tool FOR every Job,
                and
                A tool FROM every job
                • OpaDC
                  • Feb 2008
                  • 393
                  • Pensacola, FL
                  WOW
                  I'm just waiting for niki to come up with that conversion system so my car runs on salt water.
                  _____________
                  Opa
                  second star to the right and straight on til morning
