Need suggestions from the computer gurus - wireless routers
  • dewi1219
    • 307
    • Birmingham, AL
    #31
    Originally posted by JeffG78
    Hmmm, now that you say that, I DO have the WRT110.
    So how's the range on it? Thanks.
    • JeffG78
      • 385
      • Northville, Michigan - a Detroit suburb
      I'm not sure yet. 90% of the time the laptop is one floor below the router and it works great. At times, I will take it out in the back yard which is ~120' from the router. Since I got the new router three weeks ago, I have not had the laptop out in the yard. Even my crappy old Netgear router worked fine at that distance, so I don't expect any problems with the Linksys either. I haven't tried any long distance testing.
      • dewi1219
        • 307
        • Birmingham, AL
        #33
        Well, after a few minutes on the phone with Linksys (following a long hold) I got the WRT110 up and running. So far it works like a charm. In fact, I'm typing this from the comfort of my couch. I tried the laptop all over the house, and even with the less-than-optimal location of the router I get a decent signal, three bars or better, everywhere in the house. I was pleasantly surprised to find that browsing speed actually seems slightly faster with the laptop than my desktop. The laptop is a few years newer and has a better processor, more RAM, etc. Thanks again for all the advice.
        • pierhogunn
          • 1567
          • Harrisburg, NC, USA.
          #34
          Buffalo WHR-HP-54G + DD-WRT
          My suggestion, from personal experience, is
          get a Buffalo WHR-HP-54G from ebay with dd-wrt loaded on it
          It's like getting a brand new bt3100, tuned up by the experts, with a copy of every one of Rod's Jigs
          the buffalo whr-hp-54g is one of the most powerful routers on the market today.
          You can access every single little feature that you could ever want, and there is a truly massive online community, sorta like this one, that is dedicated to spreading the good word as it was.
          You really can't go wrong for $100.95 with shipping
          Oh, and I forgot the best part, you can get an aftermarket antenna for this thing, and crank up your transmit to 750mw.. literally burn a hole in your sheetrock if you have any blindspots in your house, and you have a graphical throughput monitor too boot.
          Monty Python's Flying Circus
          Dan in Harrisburg, NC
          • tewilk
            • Aug 2007
            • 79
            • Augusta, GA
            #35
            Originally posted by kirkroy
            What's a good setup for bittorrents with dd-wrt? I'm using dd-wrt on my bridging router (wrt54gs).
            The problem I have had with bittorrents have been with number of active ports, the standard firmware on most "home" wireless routers is set a low range that can not be adjusted. With dd-wrt, I was able to adjust the number of ports from 512 to 3000, which allow my router to continue to run while before it would lock up on me.
