Geek Help - XP Hanging on Loading
    On my in-laws' laptop. The progress bar stops moving. Last known good did not work. I enabled bootlogging and the log said it was FASTFAT.sys file. reseated DIMMs, then tested each and it still hung. Renamed fastfat.sys, it still hung. Chopped all non-essential stuff out of startup via msconfig, still hanging. My FIL says he has not made any changes to the machine. I've been here the last few days and AFIK he hasn't.
    Bootlooging now says it did not load fastfat (after file rename), but that is the last think it says and the machine hangs. So, what else can I try before I reload it? Or should I go back and check the bootlog for the last thing it -DID- do? There is mostly what it did not do.
    I'd be interested to hear if you get it going. I had pretty much the same thing happen last year. I wound up buying a new hard drive.
    • Hellrazor
      • 2091
      • Abyss, PA
      • Ridgid R4512
      David,
      Did you try to chkdsk the drive while you were working on it?
      I am beginning to really hate windows again. Long live *nix
      • kirkroy
        • Feb 2007
        • 343
        • Brunswick, MD
        My opinion on chkdsk is don't run it unless you've backed up data first... My opinion on windows is, if you've got a problem like this after a couple or more years of use reinstalling windows is better than figuring out the problem since there are likely other problems that a reinstall will clean up (although I set up my XP machines from the get go with a drive imaging software, Ghost, so I don't have to spend so much time on the reinstallation).
        • rjwaldren
          • 368
          • Fresno, CA
          Below is quoted from the annoyances.org website. Rather than using recovery console (does Home have the recovery console) the file can probably be replaced in safe mode. If there is no XP cd available just copy it from another system.
          Here are the easiest way to combat the problem; 1-Insert your winrowsXP CD-ROM 2-Reset your PC, and choose to boot from cd. -If you don't get that option, go into your BIOS, using F1 or Delete on most computers [if not hold INSERT while your PC is off, then turn the PC on (while still holding insert key) and keep holding insert untill you get a keboard error message. Then goto the BIOS configuration and look for the boot order and ensure your CD drive is first. 3-Allow the computer to go through the process which appears to be installing windowsXP. 4-When (3) is complete choose the option to use the recovery console. 5-Tap in the WindowsXP system, you would press 1 for most computers, and press enter. 6-type the following- COPY D:\I386\FASTFAT.SY_ C:\WINDOWS\SYSTEM32\DRIVERS\FASTFAT.SYS (where d:\ is your cd drive which you have WinXP cdrom & where c: is your hard drive where WinXP is installed) 7-Hit Y to overwrite, if you get the option. 8-Once the file has copied, and automaticly decompressed, take your WindowsXP CD-ROM from you cd drive. 9-Type EXIT Your computer should boot and run with no problems. Assuming FASTFAT.SYS was your only problem.
          • 182much
            • Jan 2008
            • 92
            • Norco, CA
            Help site
            I've had several problems, and the guys and gals here http://www.cybertechhelp.com/
            Have helped me every time.
            Saved me from buying a new hard drive, re-installing.....
              The hard drive is toast. I took the drive home and put it in a laptop here. Interestingly it booted ok. I ran a Linux based tool I have against it and that reported bad sectors in several spots. I copied the partition off to a new larger drive, tried that and it was corrupt enough that the copy failed to boot. Tried a reinstall and discovered the CD drive in the laptop here is bad. So now I gotta wait till that gets replaced...
                Problem. Windows XP hangs on load.
                Solution. Install Linux. Problem permanently solved.
                Sorry, I don't do Windows.
                  In this case with a bad/failing drive, Linux wouldn't run any better.
