Quote
  • germdoc
    • 3567
    • Omaha, NE
    • BT3000--the gray ghost
    It's obvious that when you hammer in the screw or bolt, you compress the wood fibers, which then swell and expand to fit the grooves. It would probably work better with certain types of screws and woods than others. Most modern screws are designed to cut it and create a channel. IMO you should generally use a tool or implement the way it's designed for best results. (Maybe I should copyright that remark??)
    Re' Trini Lopez: what a guitar! Wish I had one of those axes...
    Speaking of hammers, then I Tubesurfed over to this surreal bit:
    http://youtube.com/watch?v=BWFagCJAA...eature=related
    and this one, which is really where the quote probably originated:
    http://youtube.com/watch?v=5hoCYMBcNDk&feature=related
    I wouldn't let her anywhere near handtools myself...
    Jeff
    • Wood_workur
      • 1914
      • Ohio
      • Ryobi bt3100-1
      Well, if the threads are small enough, like a machine screw, it would work because the ring shanked (is that the right name ) nails do hold a lot better.
      Alex
