Simple Home Remedies
  • Anna
    • 728
    • CA, USA.
    1. If you're choking on an ice cube, simply pour a cup of boiling water down your throat. Presto! The blockage will instantly remove itself.
    2. Avoid cutting yourself when slicing vegetables by getting someone else to hold the vegetables while you chop.
    3. Avoid arguments with the females about lifting the toilet seat by using the sink (or bathtub).
    4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure on your veins. Remember to use a timer.
    5. A mouse trap placed on top of your alarm clock will prevent you from rolling over and going back to sleep after you hit the snooze button.
    6. If you have a bad cough, take a large dose of laxatives. Then you'll be afraid to cough.
    7. You only need two tools in life: WD-40 and duct tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
    8. Remember: Everyone seems normal until you get to know them.
    9. If you can't fix it with a hammer, you've got an electrical problem.
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    these are great!
    • just started
      • Mar 2008
      • 642
      • suburban Philly
      Thank you Anna, that was great!
      Art
        Those I've got to try out. I've got a #10 for ya. DAMHITK
        10. If you lift your arm and your shoulder hurts...don't lift your arm.
        • Mrs. Wallnut
          Bandsaw Box Momma
          • 1566
          Some of those are so true for my side of the family that its scary. Thanks for sharing those Anna.
          • DUD
            • 3309
            • Jonesboro, Arkansas, USA.
            Anna
            Keep it up and I will pass the jester to You. Thanks, Bill
            • rjwaldren
              • 368
              • Fresno, CA
              Don't let my wife see #5.
                Don't let my wife see #2. The way she cuts herself, I think she has stock in BandAids.
                eD
                • radhak
                  • 3061
                  • Miramar, FL
                  • Right Tilt 3HP Unisaw
                  And don't let my wife see #3; she might realize we no longer have those arguments and something might go 'click' in her mind.
                  - Aristotle
