I pulled it out and rested
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    I know You think this is dirty and it was.
    I had to unstop a tub drain in a rental unit today. As I pushed and turned the auger I got
    in about 6 feet and had to pull it out and rest My body. I rested awhile and went back in a
    and started over, it was easy except for the trap area. After I got past the trap, it was
    easier until I got to the blockage. With much pushing and turning finally the water in the
    tub went away, I then ran hot water thru it for about 5 minutes. I got it done without
    calling a Plumber. Bill
  • jhart
    • 1715
    Always good to be able to push it in and pull it out.
    • germdoc
      • 3567
      • Omaha, NE
      • BT3000--the gray ghost
      It's a dirty job but somebody's gotta do it.
      You da man!
      Jeff
      • DUD
        • 3309
        I thought of this post as I was sitting on the tub. Bill
        • footprintsinconc
          • 1759
          • Roseville (Sacramento), CA
          at the end of your post, i was expecting that you were going to describe to us what you pulled back!
          our kitchen drain got plugged a couple of months back, and i was near the end of the 25ft lead, when i hit the blockage and half of it went away, but the other half just came back all tangled at the end of the auger .
          omar
            I guess we all used to do that a lot when we were younger. It was easy to go to sleep after a workout like that.
