Anyone know or use MIL-TFP-41?
    • 22015
  • MilDoc
    Is that kinda like CFC and NFG?
      Nope...I'm stickin' with Service Pack 2.
      • pecker
        • Jun 2003
        • 388
        I'm more familiar with MIL-TFD-41c
        make it like the f*****g drawing for once.
        But then I work at a electronic defense contractor.
          That's funny cause I have a buddy that works in a large laser/waterjet shop and they routinely get drawings where someone changed a dimension without changing the part. So they do MIL-TFD-41c all the time, but then the customer still says "no good."
          • Crash2510
            • 830
            • North Central Ohio
            if you don't know what this means you need to rtfm on business acronyms you will be enlightened
            Phil In Ohio
            The basement woodworker
            • just started
              • Mar 2008
              • 642
              • suburban Philly
              Well, I never 'worked' for the government so I didn't have to learn how to speak acronym.
              • eccentrictinkerer
                • Aug 2007
                • 669
                • Minneapolis, MN
                • BT-3000, 21829
                My cousin, Keith, was a drafter back in the day when they were called draftsmen and they actually used pen and ink.
                He often used the acronym, somewhere on the drawing, HTF-GTS.
                (Hammer To Fit-Grind To Size)
                • Tom Slick
                  • 2913
                  • Paso Robles, Calif, USA.
                  • sears BT3 clone
                  obviously the FNG needs a bucket of K9P and to RTFM in order to understand MIL-TFP-41 otherwise he is NFG and his head is MT.
                  I like the HTF-GTS but we add PTM: making HTF-GTS-PTM.
                  Paint To Match
                    Good one Loring, I've heard it a time or two. Things I have put in case notes on problem tickets:
                    This is a SNAFU.
                    Something here is FUBAR'd.
                    More than once I've root caused something in the offical case notes to PIBKAC.
                    • MilDoc
                      PIBKAC! Had to look it up but I will be using it too!
                        • 22015
                        PIBKAC - that's a new acronym for me, too, but I know surely know the symptoms. That's why we start these threads, to expand our knowledge, I shall be looking for an opportunity to apply this new useful knowledge.
                        • Anna
                          • 728
                          • CA, USA.
                          PIBKAC.... Is that caused by an ID-Ten-T?
                          • unclecritic
                            • Feb 2008
                            • 99
                            • Michigan
                            • Craftsman 21829, (2) bt-3100's
                            woohoo! thank god for google
                              The automotive reference is that there is a loose screw between the seat and the steering wheel.
