Flat Washers
    Flat Washers
    If you heat a steel flat washer, will the hole get larger or smaller?
  • gmack5
    • 1972
    • Quapaw, Oklahoma, USA.
    • Ryobi BT3000SX & BT3100
    Bigger
    FROM WHAT I REMEMBER OF MY HIGH SCHOOL PHYSICS DEMONSTRATION IT'LL GET LARGER.
    It was a Ring (Kinda like a washer) and a Ball and when they heated the Ring, the Ball would pass through it, where it wouldn't go through the Ring when they were both at room temperature.
    George
      That's a good question. It seems like it would get smaller, due to the metal expanding in both directions. But what do I know? I never did the experiment above. Maybe all the expansion takes place in the outer perimeter due to "path of least resistance". Gimme the official answer. Enquiring minds want to know.
        • 22109
        it will get larger. Although you may think of metal expanding in all directions the correct way of thinking is what happens along the circumference at any given tiny slice of radius on the washer. The circumference gets longer, hence the radius will get larger.
        • DaveS
          • 596
          • Minneapolis,MN
          I recall heating/cooling the ball - not the ring.
          • charliex
            • 632
            • Spring Valley, MN, USA.
            • Sears equivelent BT3100-1
            Replacing tapered bearings. Heat the inner race and then slip it on to the shaft. If it's cold outside set the shaft out for some time before heating the inner race.
            Chas
            • germdoc
              • 3567
              • Omaha, NE
              • BT3000--the gray ghost
              The correct answer is: depends on what body part you have got stuck inside the washer and how hot you are willing to heat the washer to try to get that body part out.
              Jeff
                Is the scientific relevance called "proportionate heat variable"?
                • iceman61
                  • Oct 2007
                  • 699
                  • West TN
                  • Bosch 4100-09
                  This is absolutely correct. We use to heat large steel couplings (12" ID) with an acetylene torch with a rosebud tip until they were almost cherry red to get them to slide onto the gearbox/motor shaft. If I remember right this is called an interference fit. We also heated bearing races to get them to fit on a shaft like charliex described for tapered bearings.
                  • JohnnyLisa
                    • Oct 2005
                    • 33
                    • Pensacola, Florida
                    • Sears Craftsman # 21829
                    The photo below shows another practical application of the inner diameter expansion when heat is applied. This is a locomotive steel tire being heated with a gas ring to expand it to fit over the spoked drive wheel. When cool, the tire shrinks to fit the wheel tight enough so that there is no slippage.
                    • cwithboat
                      • Jan 2008
                      • 614
                      • 47deg54.3'N 122deg34.7'W
                      • Craftsman Pro 21829
                      To loosen a stuck lid on a jar one runs hot water on it. The glass jar is not shrinking so the lid must expand. Inner portion and outer portion.
                      regards,
                      Charlie
                      Rudyard Kipling
                      • Tom Slick
                        • 2913
                        • Paso Robles, Calif, USA.
                        • sears BT3 clone
                        the diameter gets bigger, if you don't believe it you can argue with my physics book that is open in front of me!
                          The diameter gets bigger. If it didn't blacksmiths could never have built wood-spoked wagon wheels with iron rims.
                          • TheRic
                            • Jun 2004
                            • 1912
                            • West Central Ohio
                            Actually the metal and glass both expand, the metal expands quicker (and more) than the glass.
                            Ric
