photo's - one more time
  • buddyrough
    • 164
    • playa del rey, ca, USA.
    i've done a search to find a way to post photos on this site from photobucket - unsuccessfully. i know i'm the only one that has trouble with this. directions, please.
    (why not have a section on BTcentral with a direct thread to this issue?)
    thank you
    I'm not quite clear on your objective.
    Do you want to make it so that a picutre which resides on photobucket will appear within your post on this site?
      • 22060
      for quite some time this site has allowed direct posting of photos to your article.
      click the Go Advanced button and then below the posting area find a section called "Manage attachments". That will bring up a popup allowing you to browse and copy photos on your computer to BT3central to be attached to the post.
        If you don't want to use the method Loring explains, do this:
        Log onto Photobucket.
        Navigate to the sub-album containing the image(s) you want to include in your post.
        Below each image are several lines of text. The bottom one says "IMG Code." Click on these words (at the left; it's a clickable link) and you should briefly see a yellow flyout that says "Copied."
        Come back here, RIGHT-click at the point in your message where you want the image to appear, and select Paste. The link to your image on Photobucket will be inserted into your message.
        Repeat as necessary for additional images.
        I'm a Photobucket user, and this is exactly how I post my pics. I use Firefox with two tabs open; one for the message I'm composing, the other for Photobucket.
        For formatting purposes, I've found that two or three carriage returns BEFORE the image, and at least one afterwards, gives the best appearance. That's how the example above was done. I use a maximum image size of 640x480.
          I also use Photobucket and Larry's instructions are exactly what I do.
          • footprintsinconc
            • 1759
            • Roseville (Sacramento), CA
            larry,
            now i just upload the images from my computer.
            my question is: i cannot do what you are explaining using my computer. i have to have a photobucket account or something similar, correct?
            thanks
            omar
            • buddyrough
              • 164
              Thanks Again
              Thanks for the help. It has been a long time since I've tried to post a picture and each site seems to do something a little different. Larry's method of using photobucket works very well.
              Rod
                larry,
                thanks
                Omar, you don't need a photobucket account. When you type your post, before you submit it, scroll down. You will see "manage attachments". Click on that, then follow the directions. You only need the image on your computer. You are limited to 95K (I think) in size.
                Edit: I just made a new thread on posting pics.
                • footprintsinconc
                  • 1759
                  thanks Ed! i will have to try that. i have always wondered how the pictures were inserted into the text.
                  omar
                  • Duff
                    • 164
                    • San Antonio, TX
                    • Enco 12" RT
                    Uhh...Crocket. . .isn't that Ricardo Tubbs. . ? Sorry..>Crokett. . .
                    Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
                      Omar, the method described by Ed and Loring works just fine. If you want to make the same pictures available to people beyond BT3Central (other forums, email, etc), set up a Photobucket (or similar hosting service) account and use the method I described. That's the main difference between the two methods.
                        Omar
                        I also use Photobucket. If you have your own pictures already in your computer, like in "Documents", or "Pictures" etc., once you have set up your account at Photobucket and uploaded the picture, copying the "IMG" may not set off the yellow flyout that says "copied", when clicking on the "IMG" code. Sometimes it does sometimes it doesn't. If you set the cursor (I) to the left of the image code and left click and hold down and drag to the right slowly, it will copy the code, then right click and the pull down will give you a choice to "copy". Left click on that. Then, paste into the post.
                        Other than Photobucket, here's a few hosting sites that are free:
                        http://xs.to/
                        http://www.tinypic.com This site requires no account
                        • iceman61
                          • Oct 2007
                          • 699
                          • West TN
                          • Bosch 4100-09
                          I've been wondering about that one myself, but I think earlier it was actually Crocket.
                            ... once you have set up your account at Photobucket and uploaded the picture, copying the "IMG" may not set off the yellow flyout that says "copied", when clicking on the "IMG" code. Sometimes it does sometimes it doesn't. If you set the cursor (I) to the left of the image code and left click and hold down and drag to the right slowly, it will copy the code, then right click and the pull down will give you a choice to "copy". Left click on that.
                            QFT.
                            Sigh. This little pissing match that "cabinetman" started several months ago is getting sooooo friggin' tiresome ...
                            Omar, as I said in my previous post: click on the actual words "IMG Code" to the LEFT of the code string box:
                            It's not necessary to manually copy the code string in the box at right. Just click on the words at left. It's that simple. Really. I have never had the yellow flyout fail to appear; but even if it doesn't, the code will still be copied. Except, of course, in the instance of operator error.
                            Last edited by LarryG; 01-18-2008, 01:43 PM. Reason: So there'd be no doubt about what I meant by "tiresome"
                              Omar
                              Most of us here will not find it tiresome to help you to make sure you have as much info you need to figure out how to do photos. I won't repeat my previous post as you could just go back and read it if you need to.
                              If you still need further help ask away.
