Windos XP startup issues
  • THyman
    • 315
    • Atlanta, Georgia, USA
    I've recently come across a problem with my desktop computer. The computer turns on and goes through its startup routine but when it comes to the Windows screen, it freezes. When i reboot in "safe mode" and then go to msconfig, i can load the Microsoft only programs and it reboots fine.
    I think it maybe something with Norton Antivirus. Any thoughts or recomendations.
    Thanks.
    War Eagle!
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Did you load Norton recently? Did you install any software recently?
    Also, does the machine go thru the memory check fully (and say memory is fine)?
    If safe mode works, then you should be able to enable services one (or a couple) at a time - I think, have not used safe mode for some time. Should help in eliminating problem software.
    It still is possible you have a hardware or driver problem. You could check device manager and see if any conflict shows up (yellow tag against any device).
    - Aristotle
      I know when I used Norton Anti-Virus, I was constantly having weird things happen. Not only that, but adware and spyware were still showing up on my computer from time to time. So I finally gave my computer an enema, got rid of the Norton, and installed McAfee. No problems since, with a good 2 years under my belt. Not sayin' Norton is your problem, but it certainly was mine.
      • ironhat
        • 2553
        My tech guy calls Norton 'bloat-ware' because the program has become large, cumbersome and inefficient. I dumped mine after I downloaded the '07 version and had nothing but weirdness. Un. Cracker and others have had good luck with McAfee. I'm using AVG at home and at work. They have a 'no bells and whistles', free version. Other than that I'm not much help to you.
        Blessings,
        Chiz
        • Pakaderm
          • 116
          I use AntiVir, the free version. Works great!
          http://www.free-av.com/
          -Pak
          • MBG
            • Apr 2003
            • 945
            • Chicago, Illinois.
            In safe mode you may want to try to do a system restore to an earlier date.
            ( start-accessories-system tools-system restore )
              in the safemode you can select manually OKiing items to load at startup.
              By clicking yes one at a time you can usually tell which one causes the hangup.
              or by selectively clicking no you can eliminate which ones hang the computer.
