Fixing a speaker
    Fixing a speaker
    Is it worth trying to fix a speaker? I have a dead speaker on my stereo. No sound at all. It is a KLH, not too fancy just a small 2-way I use for the front channels. Whatever I do I'd have to remove the speaker and go in that way - there is not a way to take the case apart.
    It could be something simple, like a connection, or break in one of the wires.
    • eccentrictinkerer
      • Aug 2007
      • 669
      • Minneapolis, MN
      • BT-3000, 21829
      Servicing speakers through the main speaker opening is s.o.p. A quick check with a ohmmeter will tell you if the voice-coil is intact (a AA battery with a couple of test leads works, too) just listen for click or thump). Some speakers have fuses on the crossover board. Worth a look.
      Re-building the speaker is usually very expensive. Try www.partsexpress.com for suitable drivers. If your enclosure is closed-box design most any speaker with the same diameter and magnet weight should work. It won't be optimum as designed, but usually they sound fine, unless you're a "Golden Ears" type.
      Also, it's a good idea to replace speakers in both boxes at the same time to maintain balance.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        An inexpensive speaker like that may not be worth replacing drivers, but it doesn't hurt to check the connections, circuit breakers, fuses, etc. for continuity.
          As with all other consumer electronics, replace rather than repair ;( I know its wasteful, but they leave you with little choice when it comes to dollars and cents.
            • 22108
            good advice here.
              Some speakers are manufactured with non-serviceable fuses (fusible links, they're called) wound into the voice coils. These are one-time-blow and then junk the speaker. The ohmmeter will tell you if the coil is open.
              • eccentrictinkerer
                • Aug 2007
                • 669
                • Minneapolis, MN
                • BT-3000, 21829
                Addendum to my previous post.
                I'm a fan of vintage name-brand speakers. KLH, Infinity, JBL. etc.
                Many of these old brand names have sold to companies selling crappy speakers in molded cases. They usually aren't worth saving.
                I have a pair of small KLH bookshelf speakers in my shop that never fail to impress visitors, and they're 20 years old! If anything happened to them, I'd rebuild them in a heartbeat.
                  My speakers aren't 20 years old, they are 8 years old. I will crack the speaker when I don't have anything else to do and take a look at it.
                  • BigguyZ
                    • Jul 2006
                    • 1818
                    • Minneapolis, MN
                    Personally, I got into WWing from speaker building. So, if it's not a simple matter of repairing a connection or a capacitor or something like that- I'd take advantage and build your own! If you're interested, I can point you to some good resources...
