i have a cabinet door that has 2 european hinges on the bottom (the door hides the garbage).
there is a metal ring that the garbage basket fits into, and there is a chain that is attached to the ring and the door at the other end (to prevent it from opening).
2 question:
are there hinges available that have limits built in? in other words, i would like to eliminate the chain.
secondly, the particle board on the door itself is so brittle, that i can't secure it to the hinge mounting screws. is there a strong product available that may remedy this? i tried mixing sawdust with glue, and that held for about a month.
i was also thinking about laminating some wood over the hinge drill-outs, but i don't know if there are hinges available that adjust to accomodate the extra distance of the hinge ends.
2 question:
LCHIEN
