Rockwell-Delta shaper
  • p8ntblr
    • 921
    • So Cal
    • Craftsman 22114
    What do you guys think of this one?
    http://losangeles.craigslist.org/sfv/tls/484245124.html
    -Paul
    If you really have a need and the space for a small shaper, it's a pretty cheap price. The machine looks really early, but if it runs good that's all that counts. I wouldn't recommend a 1/2" spindle model, as a well set up router table with a substantial router is more than adequate.
    Shapers can take large winged cutters, and their performance is unique with a power feeder, and very dangerous without one. I would seriously consider why you are interested in one before spending the money.
    FYI, shapers can go up to 1 1/4" spindle capacity, and are usually intended for large profiles that are run on a continuous basis. For occasional use I would still recommend saving your money and invest in a good router system.
      • 22012
      Wow, that looks really old - might predate WWII.
      I, myself, have no real desire for a shaper of any vintage. Doesn't suit my woodworking.
      • ironhat
        • 2553
        I think that I owned that one and got rid of it abut 15 yrs ago. IIRC, spindle height is controlled by a lever attached to the spindle which rides inside a tube. The handle follows a helical cut in the outer tube and it's a pretty crude adjustment compared to our present day router lifts. The machine is a brute - heavy and clumsy and slow to be adjusted. Whatever you choose, best of luck.
        Blessings,
        Chiz
