Removing Silicone Lubricant
  • andrew.r.w
    • 346
    • Canada.
    Can anyone tell me how to safely remove silicone spray lubricant from rubber, metal, plastic, etc.?
    I had my treadmill serviced, and the guy sprayed a lot of silicone lube on the deck beneath the belt in an effort to fix a squeak. The deck is impregnated with some long-lasting lubricant and does not require silicone. In fact, the belt slips on the drive roller now, and it is very annoying.
    Thanks in advance for any suggestions.
    Andrew
    I would first try plain rubbing alcohol (isopropyl). If that doesn't work, lacquer thinner should do the trick. Careful, though, lacquer thinner could melt some plastics.
      • 22044
      when we used silicone oil on O-rings for optical connectors, contamination of the optics was a problem. We could reliably clean the silicone oil with Freon-based solvents but those have been made illegal to use for ozone-depletion reasons. We had to resort to alcohol but that was much poorer in disolving the oil and had to be repeated a few times.
      • jaybee
        • 157
        • Regina, SK, Canada
        You mean freon tp-35 is illegal That means that I have to deny having any And avoid using it to clean the things that can't be reliably cleaned with anything else
        Nah!!
        I'll just keep the stash I don't have hidden from casual view
        • tuttlejr
          • 440
          • LAKEWAY, TX, USA.
          Suppliers to Paint and Body shops have a product that removes oil, wax, grease and silicone from surfaces. When I was an RM Paint jobber, the product was called Pre-Kleano. It was made from a blend of solvents. In a pinch, mineral spirits might work. You have to keep changing the paper towels to prevent reinfecting what you are working on.
          Bob Tuttle
          • gsmittle
            • 2793
            • St. Louis, MO, USA.
            Nah!!
            Don't forget to not use the stash you don't have....
            g.
            Smit
            "Be excellent to each other."
            Bill & Ted
