Tip of the Day
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    Tip of the Day
    When sanding sheetrock, close to the wall or overhead. Either use a mask, or keep Your mouth closed. Bill
    LOL! Thanks for the advice, Bill. Do I really want to know how you came about this wisdom?
    • DUD
      • 3309
      JR I think I should keep My mouth shut about that. Bill
      • Mr__Bill
        • 2096
        • Tacoma, WA
        Best not to chew bubble gum too
          Good tip. I learned the hard way.
          • DUD
            • 3309
            Ken I think I did too. Bill
            • TheRic
              • Jun 2004
              • 1912
              • West Central Ohio
              You can add no open drinks to the list.
              Ric
                • 8774
                This should go in the FAQ & FYI files!
                  Adding a few more warnings:
                  It could be scary looking in a mirror when finished sanding.
                  Make sure you blow your nose before going to Home Depot.
                  Completely dust yourself off before driving your car...you could get pulled over.
                  Use a clean rag to sneeze in...not your hand.
                  DAMHIKT
                    Dud,
                    That's why I wet sand with a sanding sponge. You can also rent a drywall sander that has a vac attach.
                    • scorrpio
                      • 1566
                      • Wayne, NJ, USA.
                      I like to sand with this.
                      And do try out that new 'dust control' joint compound - dust particles cling to each other, so you don't get that fine airborne stuff. Really cut down on mess during latest room remodel.
