more math problems
    • 22109
    more math problems
    Token 10 chars
  • Tom Miller
    • 2507
    • Twin Cities, MN
    Talk about close calls -- I almost opened a soda before I read this!
    I liked the "find x", but I think my 12-yr-old is gonna like the elephant better.
    Regards,
    • jackellis
      • 2638
      • Tahoe City, CA, USA.
      At one time in my life, I could answer most of these in my sleep. X is easy - 5, as in a 3,4,5 right triangle. The engineer who designed the ocean liner got fired because the sink temp was higher than the source temp. I'd have to think about the polynomial expansion for a while. I think the spring deflection is .15meters and the ball will return to it's original height, assuming the whole system is frictionless.
      Are you or your wife schoolteachers?
      Are
      • Alex Franke
        • Feb 2007
        • 2641
        • Chapel Hill, NC
        Not so, jackellis. There is clearly an elephant in the way.
        • ChrisD
          • 881
          • CHICAGO, IL, USA.
          Regards,
          Something about the pre-teen brain. My 12-year-old liked that one, too.
          Chris
            Token 10 chars
            Did somebody make you sit in the corner?
            • jackellis
              • 2638
              You're right, Alex. It'll hit the elephant on the way down.
              My original answer stands *assuming* there's no elephant and no friction.
              There was a running joke about what you needed to know in order to pass the first physics course every engineering student took at my alma mater (Georgia Tech). First, f=ma (force = mass times acceleration). Second, you can't push on a string.
              • Daryl
                • 831
                Tougher than I thought.
                  • 22109
                  I didn't think any of these needed explanation but apparently the software thought so...
                  "A JPEG lossy compressed image file is worth 5 kilobytes of ASCII text".
                  I had to cut and paste that 200 times on the clipboard for punishment.
                  • scorrpio
                    • 1566
                    • Wayne, NJ, USA.
                    Here's another.
                    • wade78
                      • Feb 2007
                      • 19
                      • Corona, CA
                      That is hilarious scorrpio. I will have to show that to some of the nerds at my work.
