Screen resolution poll
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    The "New Look" thread has me wondering, what screen resolution do you use on your computer(s). You may choose more than one if you use more than one computer.
    160
    640x480
    1.25%
    2
    800x600
    4.38%
    7
    1024x768
    32.50%
    52
    1152x864
    2.50%
    4
    1280x1024
    33.13%
    53
    1680x1050
    5.00%
    8
    1680x1200
    8.13%
    13
    1920x1200
    4.38%
    7
    2048x1536
    0.00%
    0
    2560x1600
    0.63%
    1
    Other
    7.50%
    12
    I have no idea
    0.63%
    1
    Sam Conder
    BT3Central's First Member
    Uhh... what poll?
    In any case, 1280x1024 at work (not that I visit BT3Central at work ) on primary monitor and 1024x768 on secondary. At home it is 1280x1024.
    • 430752
      • 855
      • Northern NJ, USA.
      was this supposed to be a poll?
      If so, I didn't see the poll selection.
      At home I run 1600x1200 60mhz (20" normal aspect lcd)
      at work, 1024x768 60Mhz (15" normal aspect lcd)
      - curt j.
      A Man is incomplete until he gets married ... then he's FINISHED!!!
      • Sam Conder
        • 2502
        • Midway, KY
        • Delta 36-725T2
        Apparently vBulletin posts the thread, then takes you to the screen to create the poll. It took me a while to type all those in!
        Sam Conder
        • Stan
          • 966
          • Kalispell, MT, USA.
          • BT3100, Delta 36-717
          Twin-headed here, each at 1600 X 1200 for a total of 3200 X 1200.
          http://www.elksigndesigns.com
            I think that's what it does, yeah. I discovered this while doing my router polls. I soon learned to compose all my choices ahead of time using TextPad, so I could tinker with the wording and check the spelling, then quickly paste them in when actually "assembling" the poll.
            • sacherjj
              • 813
              • Indianapolis, IN, USA.
              My monitors are vertical at work, so I have two 1024x1280s. At home it is dual 1280x1024s. I'll never go higher resolution, unless I can keep two monitors at the higher res. It is just so much easier to get things done.
              Joe Sacher
              • TheRic
                • Jun 2004
                • 1912
                • West Central Ohio
                1024 X 768 Not in full screen. Like to see my more important icons around the window(s) I'm looking at.
                Ric
                • Kristofor
                  • 1331
                  • Twin Cities, MN
                  • Jet JTAS10 Cabinet Saw
                  1600x1200 x3 monitors at home
                  1280x1024 & 1400x1050 at work.
                  Kristofor.
                  • Otter
                    • 865
                    • Cumming, GA, USA.
                    • Delta Left Tilt UniSaw
                    GEEKS-R-US
                    now I know why i feel at home here. Multi-monitors abound....GEEKS I see GEEKS
                    T.E. Lawrence
                      1024 X 768 - 20" monitor.
                      • TheRic
                        • Jun 2004
                        • 1912
                        • West Central Ohio
                        Originally posted by Otter
                        GEEKS-R-US
                        Otter I know what your talking about!!! I'm called a computer geek all the time and "I" don't have multiple monitors!!! I can't convince the LOML. Recently my monitor died, I'm currently on 1 (one, uno, single, etc) 15" monitor at home.
                        Ric
                        • jspelbring
                          • Nov 2004
                          • 167
                          • Belleville, IL, USA.
                          • Craftsman 22114
                          Screen Rez
                          1920x1200 - Widescreen 24" iMac.
                          To do is to be.
                          • 25
                            • 294
                            • League City, Tx, USA.
                            At home: 1680x1200
                            At work: 3200x1600
                            and 1024x768
                            • jziegler
                              • 1149
                              • Salem, NJ, USA.
                              Home: 1280x1024 on a 17" LCD (I want a 20" to run at 1600x1200)
                              Work: 1600x1200 on a 19" or so CRT (yuck). I don't like CRTs anymore. But it's what they gave me. I'd like a slightly lower res for readability, but in my work, I need all the space I can get.
