5/4 means ?
  • siliconbauhaus
    • Dec 2006
    • 925
    • hagerstown, md
    5/4 means ?
    I've never understood this reference for wood sizing. Deos this mean the wood is nominally 1 1/4 thick
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
  • ragswl4
    • 1559
    • Winchester, Ca
    • C-Man 22114
    Yes, that's what it means. Way back when someone decided to dimension wood by quarters, hence 1/4, 2/4, 3/4, 4/4, 5/4 to .....infinity/4. Good as any I guess.
    RAGS
    Raggy and Me in San Felipe
    sigpic
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      to confuse it even more it is the rough size before surfacing (most lumber has been surfaced). that means that a 4/4 board that has been surfaced (not rough) is going to be 3/4" thick. a rough 2" board is refered to as 8/4 but it will only be 1-3/4" thick.
      • Cheeky
        • 862
        • westchester cty, new york
        • Ridgid TS2400LS
        I was replacing exterior trim, and 5/4 meant 1" for primed pine, 1 1/8 for cedar and azek....very confusing and unfortunate, especially when you need something that is actually 5/4.
        Pete
        • siliconbauhaus
          • Dec 2006
          • 925
          • hagerstown, md
          gah.....blimey I miss metric so bad.
          thanks for the info though.
          パトリック
          daiku woodworking
          ^deshi^
          neoshed
          • JSCOOK
            • Sep 2006
            • 774
            • Kitchener, Ontario, Canada
            • Ryobi BT3100-1
            Now if we could only just get the USA on board with metric, it would make everything easier ...
            • siliconbauhaus
              • Dec 2006
              • 925
              • hagerstown, md
              tell me about it mate.....*sigh*
              パトリック
              daiku woodworking
              ^deshi^
              neoshed
              • Tom Slick
                • 2913
                • sears BT3 clone
                is "metric" dimensional (building) lumber in inches? like is a 2x4 still a 4x2?
                • siliconbauhaus
                  • Dec 2006
                  • 925
                  • hagerstown, md
                  yep 50 X 100 = 2 X 4
                  パトリック
                  daiku woodworking
                  ^deshi^
                  neoshed
                    • 4715
                    Yep! Metric is so dang superior! .30 Cal = 7.62mm and .223 cal = 5.56mm
                    What exactly is the difference? The placement of the decimal. Those that are endeared with the metric system good on ya but for those of us with no problems with whole number, decimals and the use of fractions I've little doubt we will wnat to change any time soon.
                    My bet is that even in metric places if you only want half of something that you get it cut in half, and if three people are splitting a pizza equally each will get one third! How the **** do you say that in metric?
                      Funny!
                      • siliconbauhaus
                        • Dec 2006
                        • 925
                        • hagerstown, md
                        Blimey.... didn't mean to get any knickers twisted.
                        All I was saying was that everything is a sensible number...ie 19 mm not .1905 (3/4)
                        IMHO fractions are a pain in the arse. I have to use a special calculator to work this stuff out.
                        パトリック
                        daiku woodworking
                        ^deshi^
                        neoshed
                        • JSCOOK
                          • Sep 2006
                          • 774
                          • Ryobi BT3100-1
                          Just gotta get you upgraded to a 9mm ...
                          1/3 = 0.33333
                          • siliconbauhaus
                            • Dec 2006
                            • 925
                            • hagerstown, md
                            raises a molson and chuckles
                            パトリック
                            daiku woodworking
                            ^deshi^
                            neoshed
                            • JSCOOK
                              • Sep 2006
                              • 774
                              • Ryobi BT3100-1
                              Hmmm ... enjoying one of our fine exports I see ... cheers!
