Okay,
I am getting ready to figure out the best way to heat my overly large shop (gloat, in case you didn't get it). My two choices so far are propane wall heaters, or electric wall heaters, both with blowers. I actually have 3 separate areas that will or could be different temps, at any one time, so a central system is out.
I have already calculated the btu requirements of each using the calculator at www.heatershop.com. I have also figured the cost of the heaters, and installations, which i can do either myself.
So really i am down to the actual energy costs and wanted some of you good with numbers to check my math if you wouldn't mind.
To keep it simple. lets say I need 91000 btus of heat, because that's what a gallon of propane will produce. ( if I heated all three area, I am really looking at well over 160,000 btu's) If i used electric it would take 27000 watts, or 27 KW's to produce 91000 btu's.
My electric rate is .0786 cents kwh, and propane is 2.39 gallon (delivered). So I figure to get the same amount of heat, it will cost $2.13 for electricity and 2.39 for propane. Electric being .26 cents cheaper per hour.
To top it all off, we are getting a 5% electricity decrease in January, and the propane man tells me to expect a .20 cents per gallon increase, resulting in electric costing 2.01 and propane 2.59, for a difference of .58 cents per hour,
So do all those numbers look right? Electricity is about 30% cheaper, btu for btu than propane?
I know there are other variables, and have figured out much of that, but didnt want to fill the thread. But for reference for those that are interested, the install rate for piping and valves is about equal to wire and breakers. For the heaters i am comparing I would need about twice as many electric heaters as propane, resulting in twice the cost.. The electric service base fee is $12.00, and the tank rental is 10.00, but i need the electric anyway.
With propane, I would have heat when the electricity was out, but would also need to worry about explosive vapors. In the bonus room section the wife could have a propane fireplace. With the wall mount electric heaters with plug (cadet garage 4000) i can move those around if needed.
Anyway, i have calculated most of the variables, and if my numbers are correct, it will cost me at the most 750.00 more to install electric heaters, than propane, but i am more efficient and comfortable installing electric. I can also try to find some eletrci that cost less per btus to buy.
At .58 cents an hour it will take me 1200 hours at 91000 btus of electric heating to break even and start saving.
So can any of your engineers or mathematicians tell me if i am right so far?
thanks
Jesse
thanks
Jesse
LCHIEN
Sounds like you are doing a decent job of insulating everything. Also sounds like you have thought out a lot of things.
