I believe this is one that if I work at it I can do it. Bill
I came across this exercise suggested for seniors, to build muscle strength in the arms and shoulders. It seems fairly easy, so I thought I'd pass it on. The article suggests doing it three days a week.
Begin by standing on a comfortable surface, where you have plenty of room at each side. With a 5-lb. potato sack in each hand, extend your arms straight out from your sides, and hold them there as long as you can.
Try to reach a full minute, and then relax. Each day, you'll find that you can hold this position for just a bit longer.
After a couple of weeks, move up to 10-lb. potato sacks.
Then 50-lb. potato sacks; then eventually try to get to where you can lift a 100-lb. potato sack in each hand and hold your arms straight for a full minute.
Once you feel confident at that level, put a potato in each sack.
