Need a battery
  • meika123
    • 887
    • Advance, NC, USA.
    Need a battery
    Some time ago, I bought an 18 volt cordless screwdriver, no name brand, from a former employee. Well, the same employee dropped the drill and broke the battery (only got one).
    My question is: Does anyone build a universal type battery for these things if you dont have a model or mfr. number.
    I have several more cordless screwdrivers, but it's always good to have another back-up-if you know what I mean.
    Thanks,
    Dave in NC
  • eezlock
    • 997
    • Charlotte,N.C.
    battery..........
    Dave, take that drill to Big Lots if you have one close by, and see if the
    18 volt battery they have there will work. It is cheap enough and may
    just be the thing to get you by. eezlock
    • MilDoc
      Or try
      http://www.batteries.com/index.asp
        • 22106
        Thanks,
        Dave in NC
        never seen a universal battery, all the mfg make the packs have different fittings and keys so they're not interchangeable unless you happen to get one made under contract for another brand, like some ryobi batteries used to fit craftsman drills.
        If you had the case you can get the packs rebuilt because they all use the same basic cells, but it you broke the case and don't know the name of the manufacturer then you are probably out of luck, don't throw out the battery pack if the one you have goes out! have it rebuilt.
