After I pulled the motor I verified the agitator assembly was free spinning. Th emotor wasn't until I pulled the pump off. So disconnected the pump from the hoses and there was a sock jammed in it.
If you find any more let me know I am missing a few sox from the laundry. LOML has a small bag the holds missmatched sox. It isn't so bad with white sox but colored one are had to match. Glad to hear
it was simple fix. Gotta wonder how that stuff get in there and how muck has passed through.
Gives new meaning to stick a sock in it!
That doesn't make much sense? Colored ones are easy to match, take a white one, and some shoe polish, crayons, lipstick, etc, and you will have a colored one. Or go the opposite, use bleach on the colored ones!
I sure hope not Sam. If one ever did make it through that pump (and I don't see how it could) then you are looking at bigger problems when your drain plugs.
