I'm thinking of getting a standby generator for the house just in case of power loss. I figure I need to add up the total wattage for things like refrigerator, television, computer, AC, fans, light bulbs. Then the total wattage should be about 70% of the generator maximum output.
Example;
Total wattage=7000w
Generator size=10000w
Is this a good estimate considering startup current are normally higher than running current for refrigerator, AC, TV?
As for wiring, should I run separate wiring to apliances and lighting, or interface with house wiring at the entry panel via manual transfer switch?
Being that I live in the NYC I'm not sure if there are codes and reguirements to consider here.
What brands are rated good?
Have any of you guys done anything like this, where do I start?
Howie
Example;
Total wattage=7000w
Howie
LCHIEN
An outstanding value, August 28, 2005
Welcome to the school of life
