Air Compressor
  • Roger on the Rock
    • 88
    • St. John's, Newfoundland, Canada
    • BT-3100
    Air Compressor
    Just got back from Canadian Tire where they had a display of compressors mis-marked to quite the consumer advantage. I've been thinking of getting one, but haven't done a lot of research. Scooped it up because of the opportunity, but can always return it.
    This one is a CH Extreme Duty 2 HP, 4 Gallon capable of delivering 4 CFM @ 40 PSI and 2.6 CFM @ 90 PSI. I'm just a hobbyist and light duty type of user, but will I be able to run an impact gun with it? How about a spray gun for light duty work? Or, am I limited to Brad Nailer's and pumping up tires?
    Any advice would be appreciated.
    Thanks,
    Roger
    • 22108
    Thanks,
    Roger
    probably not a spray gun which needs sustained high volumes of air, except perhaps the "Critter".
    A impact wrench for short bursts, not high duty cycle. You may only need short bursts to break a bolt loose but if you want to remove all four wheels (20 lug nuts) from car on a lift in a hurry it probably won't work.
    • Roger on the Rock
      • 88
      • BT-3100
      Thanks much. Yeah, I don't intend on doing a lot of high volume stuff with it and I like the portability. If I have to wait for it to charge the tank up again every now an then, that's fine. The Costco tool package I'm looking at recommends a 1 to 2 HP minimum and I think the CFM of this one will be OK for what I'm going to use it for. Seems like a good quality unit as well.
      Cheers,
      Roger
