Electrical
  • rabmaxx
    • 150
    • Henderson, Nevada.
    Electrical
    I have recessed can lights in my kitchen which came with 65 watt bulbs. Is there such a thing as a safe maximum wattage for a flood lamp.
    Ron
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    the new florescent flood lights are very low wattage but put out alot of light and are instant on. a 20 watt florescent flood is equal to 100 watts incandecent flood. the downside is they don't always fit in the fixtures.
    • Otter
      • 865
      • Cumming, GA, USA.
      • Delta Left Tilt UniSaw
      every can has a max wattage ratting, it has more to do with heat than total power.
      Wattage is a messure of the rate energy expended, with lights, that comes out as photons and heat. The "Can" can disapate so much heat per hour (BTU), so there is a max wattage based on the "Cans" radiation ability.
      T.E. Lawrence
      • just4funsies
        • 843
        • Florida.
        There should be a sticker visible inside the can with the fixture's maximum incandescent wattage rating. That comes more from a heat rating than from brightness limitations. You may be able to find a brighter flourescent bulb that can fit such a fixture, but I don't recall seeing any standard bulbs brighter than 65 or 75 watts for that type of can (assuming it's a BR30 style).
        • rabmaxx
          • 150
          Thanks for the help guys.
            The in-the-ceiling cans are sometimes well insulated by the ceiling cavity, sometimes filled with fiberglass insulation if its near the roof.
            Each can usually has a wattage rating - that's a value the manufacturer thinks will lead to a temperature rise in the above situation, where the temperature rise will not cause a fire or failure of the electrical components immediately or over time.
            The wattage should be clearly marked somewhere.
            Unfortunately incandescant lights are very inefficient - they put out less than 1% of their energy as light and the rest as heat. Basically the heated filiment gives off energy across a broad band of frequencies, a small part is in the visible spectrum the rest in the infrared which is heat.
            Someday we'll have LED lighting which will put out a narrow range of light very efficiently.
            In the meantime, don't exceed the rating of your cans.
            • rabmaxx
              • 150
              Thank you Loring-now the trick is-get up that vaulted ceiling, crane my arthritic neck, peer into that small aperature as my glasses slip down my nose, realize I forgot my flashlight as my wife is admonishing me to not fall.
              Ron
