Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: DIY tree stump removal, drill bit getting caught?
  1. #1
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,410
    I think I know the answer here but I wanted to ask...
    Last year, when Hurricane Ike came through, I lost 5 trees on my property. I have been looking for a reasonable means to remove the stumps, and the one that keeps popping up from friends and neighbors is a product called Stump Out. I read the instructions, and have helped a neighbor with his after the stump out did its thing on an oak stump, and it was like chopping out balsa wood after it did its thing. Nice and easy...
    I am trying to prep one stump, a 12" diameter Beech stump, per the MFG directions, which is to drill a 1" diameter hole 12" deep.
    I am trying to use my Irwin Speed Bor Max boring bit and extension for the job, and it mostly works okay...
    But it seems like I have to barely touch the hole, and back the bit out to clear the sawdust or the bit gets jammed in the hole and I need to back the bit out...
    Is there a better bit that I can use that will eject material from the hole better?
    The rest of the stumps are MUCH smaller, with the next largest stump 4" diameter Chinaberry junk that is actually in the Bayou but keeps trying to grow accross and on to my property...
    My personal workshop blog is http://daves-workshop.blogspot.com. My camping / hunting / outdoor blog is http://wildersport-outdoors.blogspot.com/
  2. #2
    Join Date
    Dec 2002
    Location
    Katy, TX, USA.
    Posts
    17,170
    no direct experience with it but maybe an auger type bit would help eject the cuttings while drilling - the speedbor MAX is one of those flat spade bits that won't really eject cuttings.
    Like these augers from Lee valley:
    http://www.leevalley.com/wood/page.a...at=1,180,42240
    the text says they are excellent for softwoods and green woods.
    only problem is the 18" long one costs $31
    Irwin makes a SPEEDBOR SHIP AUGER 1" Dia x 17" long
    http://www.irwin.com/irwin/consumer/...2&search=false
    http://www.amazon.com/Irwin-Industri...1210248&sr=8-7
    also $30.43 at Amazon.
    Another:
    http://www.amazon.com/Milwaukee-48-1...210605&sr=1-15
    there are shorter ones for cheaper but they won't bring the cuttings all the way to the top!
    So, how much are you saving by DIY?
    PM me (with your e-mail address) for a copy of the BT3 FAQ current vers 4.13
  3. #3
    Join Date
    Jan 2003
    Location
    Mebane, NC, USA.
    Posts
    10,624
    Stump Out takes forever. A quicker way is to go get some heavy mesh wire. Make a cage around the stump that is 2-3" bigger than the stump all the way around and several inches higher. Fill it with charcoal. Light the charcoal. Refill as necessary and in 24hrs or so your stump is gone. You can help speed things up even further by drilling several 1/2 or 3/4" holes in the stump and pouring in some diesel. Wait till it soaks in, do it again a few more times. If you are in a neighborhood though I would just stick with the charcoal. I dig a trench around the stump and clear out combustible materials and then I try to keep the trench damp.
    I have a Rigid auger bit with bigger flutes than my Irwin auger that does a better job of clearing chips.
  4. #4
    Join Date
    Feb 2008
    Location
    Midlothian, VA (Richmond)
    Posts
    424
    You definitely want an auger bit. The paddle bits are best used horizontally or for overhead vertical because they do not move the chips out.
  5. #5
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,410
    The reason for the Stump out is that burning is not required. (But does make for a lot less chopping and digging of porous debris)...
    This stumps roots run under a wooden fence, and are generally where clearing out combustibles is not going to be an easy task...
    I have time, I can wait for the chemical action to work...
    The Speed Bor is a flat blade spade bit sure, the Speed Bor Max which is what I am using, is a wierd exaggerated something between a twist drill, and an auger bit.
    I hadn't thought of grabbing an auger bit (there is a reason I ask these things here!).
    I found a Hitachi 1 inch x 22 inch auger bit on Amazon, yeah it's not cheap, but it's a LOT cheaper than getting a tree service to dig this thing up...
  6. #6
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,410
    Quote Originally Posted by LCHIEN View Post
    Lowest quote I got for stump removal for all 5 is $750.00 so DIY is worth the effort...
  7. #7
    The wood is wet and so it clogs.
    I drill lots of small holes, I happen to have a long small bit. I then slowly fill the holes with something flammable, like Colman fuel from a rusted bottom can or last years mower gas or, used lacquer thinner. Then I let is seep in and repeat. stand back and light, if lucky it will burn. Then just fill the hole every spring for years after.
    Bill, over here where it's still morning
  8. #8
    Join Date
    Apr 2007
    Location
    Fort Worth, TX
    Posts
    4,217
    I figured you'd be using that badass truck and ripping them out of the ground.
    An auger bit should help with the holes.
    Join Date
    May 2003
    Location
    Minneapolis,MN
    Posts
    594
    Quote Originally Posted by dbhost View Post
    My local rental place rents a stump grinder for $100 a day.
    I'm not sure I'd try it, that machine scares the begezus out of me. It looks like some sort of machine from the movie "Road Warrior".
  10. #10
    Join Date
    Jul 2006
    Location
    Minneapolis, MN
    Posts
    1,818
    Where do you get stump out? How much does it cost? I have a bush that I need to rip out, and the last one I did took forever/ is taking forever to get the stump out....
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
