Clamp Rack
  • Eric
    • Jun 2003
    • 653
    • Cocolalla, ID
    • Grizzly G0691 & BT3100
    Clamp Rack
    Had to remove the big clamp rack I had on my wall, and decided that a movable cart would be handier for my shop.
    I took a Harbor Freight Furniture Cart 18x30, screwed a couple 6' 2x4s at a 15° angle top and bottom to it, and 2 other 2x2s on the back side at 15° also.
    Then cut some 3/4" Plywood scraps 2" x 18" and screwed them to the 2x4s and 2x2s at 12" intervals.
    Holds most of my clamps and should help keeping them gathered up.
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    That is neat! I like the idea of using a Harbor Freight Furniture Cart as base. Smart!
      • 1865
      Great solution, i like it!
        • 10453
        Good thinking to find a use for the HF furniture dolly. Probably cheaper than buying the casters and wood to build the bse.
          • 3195
          Necessity is the mother of invention - Nice Job. Is it stable when loaded?
          • Eric
            • Jun 2003
            • 653
            • Cocolalla, ID
            It has been, probably a little taller than I needed. Loading the bottom with clamps would help. Also thinking of adding plywood across the bottom to hold maybe some glue or odd clamps.
              • 4715
              Nifty solution Eric.
                Internet Fact Checker
                • 21027
                Good idea.
