What glue to use to glue felt to wood
  • DonHo
    • 1098
    • Shawnee, OK, USA.
    I'm wanting to put a felt back on a couple of chess boards I've made for my grandsons. I'm concerned that "wood" glue might soak thru the felt and make it hard in spots. Any input will be welcome. Thanks
    DonHo
    Don
  • gmack5
    • 1973
    • Quapaw, Oklahoma, USA.
    • Ryobi BT3000SX & BT3100
    Two methods come to mind........
    One, use double faced tape like they use to hold carpet seams together, and the other one would be to use a rubber cement, used like a Contact Cement.
    Put the rubber cement on both pieces sparingly then bring them together, using a slip sheet between the surfaces, just make sure the Cement is dry (not tacky) to the touch before you start to bond them together. I'd try it out on a couple of scraps first just to be safe.
    George
    • Tom Miller
      • 2507
      • Twin Cities, MN
      I'd try the 3M #77 (or whatever) spray adhesive. Not the removeable kind, but the "super" kind.
      Caveat: I've never tried it for this application -- just seemed like it would work well. Definitely worth an experiment, especially if you already have some.
      Regards,
        Thinking back to Paul's jewelry box thread the other day, I'm wondering whether flocking might not be the better choice ...???
        Seems like every felt bottom I've ever seen on something eventually rolls at the edges, or develops wrinkles.
        • newood2
          • 600
          • Brooklyn, NY.
          Check out this link http://www.thistothat.com/
          Howie
          • DonHo
            • 1098
            • Shawnee, OK, USA.
            Well the "this to that" webpage said 3m77 also so I guess I'll give that a try. I hadn't even thought of "flocking" as a posibility and I guess it might work but I've already got the felt so I'll try that.
            Thanks for the input
            DonHo
            Don
            • offthemark
              • 193
              • Germantown, TN, USA.
              I've done this to quite a few pieces and just good old wood glue. Never seemed to bleed through. Try a sample on a piece of scrap.
              Mark
              "There are no stupid questions - just stupid people"
                Internet Fact Checker
                • 21062
                yes, 3M spray adhesive works for gluing felt. Make an even, sparing application so there's no wet spots, hard spots and soft spots.
                • monte
                  Forum Windbag
                  • 5242
                  • Paw Paw, MI, USA.
                  • GI 50-185M
                  I vote for the 3M spray also.
                  Monte (another darksider)
                  • Steve Case
                    Handtools only
                    • Dec 2016
                    • 2
                    DonHo
                    Zackly what I'm doing. I've looked at several sites on a Google search and it looks like the 3M77 spray is the stuff to try first.
                    Nolen is going on 8 and his chess improves every time we visit.
                    • Steve Case
                      Handtools only
                      • Dec 2016
                      • 2
                      My post comes up Unapproved ????
                        LCHIEN commented
                        Sorry, new members have to have their initial posts reviewed and approved by one of our moderators - we used to have a lot of trouble with spammers. Its only 20 minutes old and already approved. Is that OK?
                        BTW, note by the dates that you are responding to a 11 year old thread. That's OK.
                    • tfischer
                      • 2343
                      Spray adhesive, or a thin coat of white glue should work fine too.
