Blade will not raise or lower
  • thestinker
    • Oct 2005
    • 613
    • Fort Worth, TX, USA.
    I've got a BT3100 that the blade was tought to raise or lower. I popped the side off and blew out the inside and added some light oil to the raising and lowering screw that moves the saw motor up and down. It didn't really help any and now the crank will just spin, but not engage the gears that turn the raising / lowering screw. Any ideas on how to fix this or is it pretty much hosed?
  • Black walnut
    Administrator
    • Aug 2015
    • 5453
    If the raise/lower pinion gears are not turning have you locked the bevel lever all the way to the right?
      Internet Fact Checker
      • 21052
      That makes sense.
      If the gears and elevation screw were turning that would be a stripped thread in the locker bracket, but you said the bevel gears were not turning which fits with BW's suggestion.
      • Kangaman
        • Apr 2016
        • 8
        First post so please excuse the lack of terms..
        I have just purchased a BT 3000 (craigslist) and had an issue with raising the blade.
        I performed a complete tear-down and discovered the dreaded shim issue. After reading several posts and discussions going back to 2007, I upgraded the shims and Guide holder to ones from a BT3100 (ebay)
        I fitted these on the weekend - use some light oil to lubricate (will pay for that later).
        Wow - all now works smoothly - not sure if this is related to what you are having.
        I do have other issues, but I will create another thread for that..
        Paul
        • JoeyGee
          • 1509
          • Sylvania, OH, USA.
          There are several threads pertaining to raising and lowering, in addition to the tilt function with lots of great info on how this mechanism world and what to do when it doesn't work.
          I'd link to some now, but I'm having issues searching from my phone. Just do a search on raising and lowering, tilt, etc.
          • TylerMcDowell
            Handtools only
            • Apr 2015
            • 2
            I been hit with the shim issue as well and am working on fixing them. The problem I have ran into is the head of the screws are stripped and before I start working on them with a screw extractor thought to see if there are anything I should watchout for? I know I didn't strip them, because I have been luck enough not to have to work on my BT3100 until now. I was also looking for replacements screws and they seem to be hard to find. Is there an alternative that would work as well for replacements?
              • 21052
              well, I just lubed the shims in my 1999 BT3000 with Johnson's paste wax. Still got the original shims going strong. lube them a couple of times a year and keeping the inside pretty clean with a DC in use most of the time. so no serious dust buildup.
Name:	johnson paste wax.jpg
              • Kangaman
                • Apr 2016
                • 8
                Nice to know.
                Does this cause saw dust build up or stickyness?
                Paul.
                  • 21052
                  No stickyness. Its considered a dry lube so it doesn't seem to attract dust like oil and grease.
                    • 4715
                    My advice is to just drill the heads off. Then once everything is disassembled you can use visegrips to remove the stud that is left. You will need 4 10-24x1" and 2 8-32x3/4" all of these should be pan head. Any hardware store should have both sizes as they are rather common. I am assuming that you live in North America, if not there are other options....
                    • ejs1097
                      • Mar 2005
                      • 486
                      • Pittsburgh, PA, USA.
                      This happened to me recently, after taking the knob off, the plastic gears in the knob are stripped. My short term fix is vice grips.
                      Eric
                      Be Kind Online
                        • 21052
                        That sounds right - all the BT3x00 hardware is SAE standard threads. Any US hardware store should have replacements.
                        • thestinker
                          • Oct 2005
                          • 613
                          Hello all. Sorry for the delayed response regarding the tilt on the saw. Yes moving the lever allows the blade to tilt and lock into place. This is limited to raising and lowering the blade. Like its binding up, but there noting under the saw motor or inside where the blade is.
                          • TylerMcDowell
                            Handtools only
                            • Apr 2015
                            • 2
                            Thanks for the information. I am going to take care of this over the weekend. It's been a great saw and I have never understood why Ryobi never fixed the few problems and made a BT3200.
                            • BMiles
                              Handtools only
                              • Jan 2017
                              • 8
                              • Massachusetts
                              • Ryobi BT300
                              Hi Everyone,
                              I've been also having problems raising my blade. I think my problem is with the clutch and spring. I cant figure our how it is supposed to work or how to get it taken apart. I have a short video of it turning but cant figure out how to post that. here are a few photos
                              other questions,
                              BT3's can not be found new anywhere, correct?
                              are there any saws made now that are comparable to it?
                              are replacement raising and lowering wheels only made of plastic?
                              thank you
                              (first time here)
