Blade position
  • buddyroo
    • Aug 2006
    • 90
    Blade position
    I am in the process of assembling my new BT3100. Looking at the saw from the front, the blade is very far to the left side of the throat plate. There is probably only 1/8" clearance between the blade and the throat plate on the left side. Is this normal?
  • RayintheUK
    • 1792
    Yes - the "extra" clearance on the right is to allow for the blade to be tilted when making bevel cuts.
    Ray.
    Did I offend you? Click here.
    • buddyroo
      • Aug 2006
      • 90
      Thank You
      That is what I thought, but I know enough not to assume too much. Thank you for your fast response.
        Internet Fact Checker
        • 20990
        what Ray said.
        As long as the blade lines up OK with the splitter part of your blade guard.
        The BT3 FAQ may help you with other questions about your saw.
