Mobile Planer Cart
  • Brian G
    • Jun 2003
    • 993
    • Bloomington, Minnesota.
    • G0899
    Mobile Planer Cart
    This is a "whatcha-got" project. . . you know. . .whatcha-got in the scrap bin?
    The sides, door panels, top, and bottom are of maple/birch ply. The edging around the top and the face frame is red oak. The door and drawer trim is ash. The drawer sides are aspen, and the drawer bottom is a "wrong-way" piece of baltic birch plywood.
    The opening above the drawer is a "pass-through" so that I can better keep track of the order I send boards through the planer, and so that I have somewhere to put the boards within easy reach. If it doesn't improve my planing efficiency, then I can always fill it with a drawer.
    I got a chance to practice with the HF dovetail jig on the drawers. I need more practice! [B)]
    I was going to use the cabinet base to store my OSS, but I goofed and didn't account for the fact that the spindle doesn't detatch, so it wouldn't fit. [:0] It does, however, provide a good space to store my air compressor, 18g brad nailer, new 16g finish nailer, and 1/4" air stapler.
    The finish is semi-gloss poly.
    Brian
  • Ken Weaver
    • 2417
    • Clemson, SC, USA
    • Rigid TS3650
    Nice work Brian! Every cabinet in my shop came from the scrap pile or cull bin at the BORG.
    Ken Weaver
    Clemson, SC
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Lookin' good, Brian
      How come the spindle doesn't detach? How do you change sizes?
      Downunder ... 1" = 25.4mm
      • Brian G
        • Jun 2003
        • 993
        • G0899
        Thanks, guys.
        Rod, perhaps "spindle" wasn't the correct word. I have the Ryobi OSS. The sanding sleeves fit over rubber spindles, which then slip over a hmmmm. . . .well. . . .uh. . . spindle. That's the part that doesn't detatch.
        Brian
          Good looking cabinet, Brian. Most of my shop cabinets are from Dumster Dive finds around local cabinet shops.
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            Nice job Brian. Most of my shop cabinets have also been built from whatever I had laying around at the time.
            Monte (another darksider)
              Nice use of re-cycled stock. Also beats the crap out of picking that planer up and setting it on the bench everytime you want to use it.
                Very nice indeed. Great way to use that scrap wood.
                  It looks like your scrap bin can beat up my materials rack.
                  The pass-thru is really clever. I'm going to remember that, possibly rip off your idea, don't expect royalties. (Hmmm, you know, you could maybe have the best of both worlds by fitting this space with a removable drawer. When you need to use the planer, just pull the drawer out and set it aside.)
                  I see that you folded up the infeed table so we can't tell what brand of planer this is. I guess that was because of the TV crew, eh?
                  • BobSch
                    • 4385
                    I like the pass-through idea, too. As far as hiding the brand — you better paint it something other than bright yellow
                    Bob
                    • Tundra_Man
                      • 1589
                      • Sioux Falls, SD, USA.
                      Very nice! Once again I'm amazed at the quantity and quality of everyone's scrap bins around here. I'd have a hard time building a small birdhouse with mine!
                      Terry
                      • Brian G
                        • Jun 2003
                        • 993
                        • G0899
                        Hey, I only make high quality mistakes in large quantity. . . .that's why I have high quality scrap in large quantity. [B)]
                        Larry, good idea about the removable drawer. I think, though, I'd better get to work on the china hutch/buffet that LOML has been patiently waiting for the last year and a half. Otherwise, I fear I might gain a pass through of my own. [:0] If you get to feelin' guilty about royalties, just slip a few bucks into the BT3Central fund.
                        TV crew. . . . heh! America's Funniest Videos could probably make a whole show out of me in the shop. [:I]
                        Brian
                          Great looking workmanship, Brian.
                          Get a lathe, you'll run outa scraps real soon!
                          ken
                          • Brian G
                            • Jun 2003
                            • 993
                            • G0899
                            Money, too.
                            I "baptized" the Knuckles-Brand™ Mobile Planer Cart over the weekend by running a bunch of oak through the planer. The pass-through was very helpful, so I'm glad I incorporated it into the design. I had four stacks of boards for four shelves, and the pass-through allowed me to keep the stacks together, and helped me keep track of which side of the board to plane.
                            I didn't realize until I was done that I had forgotten to lock the casters. It's so heavy that it didn't roll on it's own, but I did have it setting on the floor matting, so the compression of the matting probably kept it from rolling.
                            Brian
                              OK everyone. What's a good height for a planer cart?
                              I have a suspicion that the planer bed should be at a level that
                              with my arms straight down I should be able to hold a board level with the infeed bed and not have to bend or stoop to feed it nor have to lift heavy boards too high tiring myself when i have a lot to plane repeatedly.
                              Which would put it around 31".
                              What do you think?
