I just bought a new BT3100 to replace my 40-yr old Craftsman radial arm saw (inherited from Dad). The radial arm saw was hard to set up for ripping and seemed dangerous in this mode.
I want to rip multiple battens (3/8" x 3/4") from 3/4" planks. However, on the BT3100 the rip fence can not be set close enough to the blade to cut 3/8" because of interference with the blade guard assembly. It seems that I have three choices: 1) remove the blade guard assembly and riving knife, 2) raise the blade high enough to allow the anti-kickback mechanism to clear the rip fence or, 3) cut the batten off of the "other" side of the board and re-set the fence to cut each batten. I don't really like any of these choices. Choice 3 is certainly the safest, but it is important that the battens all be the same thickness and accurately re-setting the fence for each cut looks difficult. Any good ideas?
Thanks,
Thanks,
LCHIEN
