Craftsman Micro-Positioning Device ref chart
  • kirkroy
    • Feb 2007
    • 343
    • Brunswick, MD
    I made up a reference chart for the Craftsman Micro-Positioning Device (probably works with the ryobi badged one as well, I assume they're the same) for my own use and thought someone else might find it useful as well. It'll print nice if you use a fixed pitch font (e.g., courier).
    http://www.sears.com/shc/s/p_10153_12605_00922214000P
    1/4 turn = 1/64
    1/2 turn = 1/32
    3/4 turn = 3/64
    1 turn = 1/16
    1 1/4 turns = 5/64
    1 1/2 turns = 3/32
    1 3/4 turns = 7/64
    2 turns = 1/8
    2 1/4 turns = 9/64
    2 1/2 turns = 5/32
    2 3/4 turns = 11/64
    3 turns = 3/16
    3 1/4 turns = 13/64
    3 1/2 turns = 7/32
    3 3/4 turns = 15/64
    4 turns = 1/4
    4 1/4 turns = 17/64
    4 1/2 turns = 9/32
    4 3/4 turns = 19/64
    5 turns = 5/16
    • 22108
    1/4 turn = 1/64
    1/2 turn = 1/32
    3/4 turn = 3/64
    1 turn = 1/16
    1 1/4 turns = 5/64
    1 1/2 turns = 3/32
    1 3/4 turns = 7/64
    2 turns = 1/8
    2 1/4 turns = 9/64
    2 1/2 turns = 5/32
    2 3/4 turns = 11/64
    3 turns = 3/16
    3 1/4 turns = 13/64
    3 1/2 turns = 7/32
    3 3/4 turns = 15/64
    4 turns = 1/4
    4 1/4 turns = 17/64
    4 1/2 turns = 9/32
    4 3/4 turns = 19/64
    5 turns = 5/16
    That's a good idea, why don't you also put decimal fractions, very useful if you use calipers to check your rip width and need to creep up 0.025"
    (Hint 1/64th = .016 and 1/32 = .031 so 0.025 would be about 1 full mark and 2/3rd of a mark.
    I've done this kind of work before with my micropositioner and the incremental fractions marks will get you better than .005", if you round to the nearest half mark then you can get to better than .010"
    I'm not really saying everyone needs to get better than 1/64th but having the decimal equivalent can save a trip to the calculator if you are checking your width with calipers.
    • kirkroy
      • Feb 2007
      • 343
      • Brunswick, MD
      Sure, that's easy enough since I did it in Excel. I'll just post up the Excel file.
      Update, with decimals:
      http://wkak.net/tools/Micropositioner_ref_chart.xls
