microplane sanding discs
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    I recall that someone on here had did a review of the microplane sanding disc and was wondering how they were holding up. I searched but couldn't find the topic. I assume it got lost and starved to death in the great migration.
    Lakota's Dad
  • jnesmith
    • 892
    • Tallahassee, FL, USA.
    For what it's worth, I have read several reviews. Maybe 4 or 5. All were negative. I had great hope for this product, but based on the unbiased reviews, they aren't there yet.
    John
    • mschrank
      • Oct 2004
      • 1130
      • Hood River, OR, USA.
      The thread is HERE
      Don spelled it "Micrplane," that's why you didn't get a hit.
      The review is on Don's webpage: HERE
      • rja
        • 422
        • New Kensington, Pennsylvania, USA.
        I don't post here very often but I could not pass this time. I purchased a course, medium, and fine set of disks and tried them out on cutting boards. They worked ok for about ten minutes each and then totally crapped out. By that I mean the holes in the disks plugged up with dust and chips and created high spots in the disks, one of which damaged the ROS hook and loop backing pad. The disks cut aggressively which made controlling the ROS very difficult. Once control technique was established, the holes plugged, and then the disks would no longer adhere to the ROS backing pad and just spun off. Even with the fine disk, the surface of the cutting board was unacceptably rough. This is a product best avoided.
        • Russianwolf
          • 3152
          okay, since the topic was found and now we recall who did the review.....
          Paging Don Hart:
          How are those discs holding up? Have you been using them regularly?
          Lakota's Dad
          • Jim Frye
            • 1364
            • Maumee, OH, USA.
            • Ryobi BT3000 & BT3100
            Been There, Did That, Didn't Like It
            I received the 3 disk combo set as a Christmas present. I found the medium and coarse cut very agressivly and were hard to control. They left scratches on the workpiece. The fine barely cut at all. I haven't thrown them out, but can't seem to find a reason to use them. Definately not like the previous products by this name.
            Jim Frye
            The Nut in the Cellar.
