Inspired by Rod Kirby's dust collector for his drill press I made one too. Being a copycat I wouldn't make a big deal of it except i made some improvements that simplify it a lot.
The original Kirby arm:
I simplified mine by getting rid of the big boxes on the ends - makes it smaller, lighter and easier to get in. I made the arms 7" x 1.5", I think Rod's were 2" wide.
I made the base a simple Ell that you clamp to the DP table with a clamp.
Instead of T-nuts installed in the arms, I simply drilled a 1/4" hole and countersunk with a 7/16" brad-point and forced the head of a 1/4-20 bolt into it (takes a 7/16" wrench so the points of the hex just dig in). For tightening I used some three-wing knobs which look nice.
For the nozzle I simply took the one that came with my shop vac, a crevice tool you can buy at Lowes for $5 or so. It has a tapered body so its easy to jam into a 1.375" Forstner-drilled hole. I had to make a right angle thing with enlarged hole area, but you could make a 2" wide rectangular piece with less work. The square area on the end was to be for a split clamp but the wedge fit of the wand made it un-necessary. I should have made just a nice ring on the end.
Anyway the finished product works well and sucks up the drill chaff.
Couple of notes:
I left clearance at the head so I could attach a 1-1/4 X 2-1/2" hose adapter should I need to use a bigger hose.
In retrospect Probably a 1" wide arm will be more than sturdy enough; I used 1.5" and Rod used 2". Using 1/4 x 20 wing nuts can make it even cheaper to make, they're only a few cents each and easily available instead of a dollar per knob, if on a budget.
Used Poplar instead of Marine plywood.
Credit for the original design and thanks for the inspiration to Rod.
I haven't made me one - yet - but was thinking this may provide a use for the router dust collector tube that comes with the accessory kit. I don't have a use for that piece, but just couldn't throw it away.
BobL.
Looks great, Loring! I'm curious: is it effective for spindle-sanding, too? I do not have an OSS and use my DP for this task. I was thinking of constructing a down-draft to add on to my DP table, but if your and Rod's method works well, I'll just copy it.
