The subject of chisel sharpening on a belt sander came up (somewhere) so I thought I post this simple jig. The jig is mounted to a Rigid oscillating belt (and spindle) sander. It has two fixed positions (25 and 30 degrees), but someone skilled in the art
can see it could be made adjustable. The baltic birch pieces that support the (hand held) blade are mounted to a piece of MDF, which is clamped to the sander table.
At the 25 degree position, the finest grit leaves the main bevel "good enough". Then I switch to the 30 degree position to start the micro bevel, and finish it up by hand with scary sharp.
Regards,
Regards,
