Chisel sharpening on osc. belt sander
  • Tom Miller
    • 2507
    • Twin Cities, MN
    The subject of chisel sharpening on a belt sander came up (somewhere) so I thought I post this simple jig. The jig is mounted to a Rigid oscillating belt (and spindle) sander. It has two fixed positions (25 and 30 degrees), but someone skilled in the art can see it could be made adjustable. The baltic birch pieces that support the (hand held) blade are mounted to a piece of MDF, which is clamped to the sander table.
    At the 25 degree position, the finest grit leaves the main bevel "good enough". Then I switch to the 30 degree position to start the micro bevel, and finish it up by hand with scary sharp.
    Regards,
  • final_t
    • 1626
    Very nice, I was thinking about doing the same thing with mine, but couldn't quite visualize how it would look (plus worried that the oscilation would be "bad"). Did you make plans for it, etc? I, for one, would love a bit more detailed look at it...
      What is the grit on the sandpaper you use? I think 120 is the finest I have for the belt.
        That is much too cool. Since I just happen to have some 3/4" BB scraps of about the right size, I'm going to build one of these this weekend (assuming it doesn't get too cold).
        JR beat me to the question about belt grit.
        • Tom Miller
          • 2507
          • Twin Cities, MN
          IIRC, I may have only used 220 since I didn't intend to remove much material. Even then it was more aggressive than I expected, so 120 might be too much. I'd suggest caution until you see how quickly this cuts.
          No plans beyond what you see in the picture -- the first layer of 3/4" baltic birch is just there to elevate the chisel so the handle doesn't hit the base (MDF). The second piece registers the blade at the correct bevel angle and at 90 degrees to the base. This is the part that could be made to rotate so you could do any angle.
          Regards,
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            Nice idea Tom!
            Monte (another darksider)
            • scmhogg
              • 1839
              • Simi Valley, CA, USA.
              Tom,
              Thank you for reposting the picture. It is just what I need for the lot of old funky chisels I got on ebay. I did an old 1/4" mortise chisel by hand using "scary sharp". I went up to 2000 on my glass plate. This old, obviously hand wrought, chisel is as sharp as a razor and seems to hold the edge really well.
              Did you have any trouble with heat using 220 grit?
              Steve
              • Tom Miller
                • 2507
                • Twin Cities, MN
                I guess since I re-uploaded the picture in another thread, it showed up again here. Deja vu all over again.
                Steve, yes the heat build up somehow came as a surprise to me. Maybe because the belt is moving slower than a grinding wheel I expected much less. It's not unmanageable, though.
                And, yes, it is just the ticket for a batch of old iron!
                Regards,
