Another lift, the "Benchlift"
  • big tim
    • 546
    • Scarborough, Toronto,Canada
    • SawStop PCS
    I built this bench and the benchlift about 5,1/2 years ago, shortly after
    I bought my BT3000.
    The bench is an adaptation of a bench in “Making Workbenches”, a
    book by Sam Allen. The lift is my own idea.
    The legs are fir, the stretchers spruce and the top is made of 3 layers
    of ¾” MDF with a sacrificial layer of ¼” masonite(hardboard) with
    a “skirt” around it from ¾” oak. The whole bench can be disassembled,
    The stretchers and legs are held together with long threaded rods,
    nuts and washers. The top is held onto the upper stretchers with
    clips.
    The pull-out shelf is to hold tools, I use frequently, etc., it tends to
    become a bit of a catch-all though, sometimes. Just below the top is
    a ¼” panel that slides out, it stops sawdust etc from falling through
    the benchdog holes onto the tool shelf. I store the handle for the jack
    there. The bottom shelf lifts out, it’s where I put scraps, cut-offs, etc.
    The benchdog holes are ¾” and the benchdogs are ¾” dowels with a
    short piece of hose around the top to keep them from falling through
    the holes
    The end vise is a twinscrew vise from Lee Valley. The vise at the front
    is a quick release vise. The standard vise lying on top of the bench is
    mounted on a ¾” piece of plywood bolted through a piece of 2x4 and it
    can be clamped in the wood vise so I don’t damage the wood vise if I
    want to work on metal stuff.
    Because my shop is small, I need to be able to move the bench
    sometimes. It’s a heavy brute. I estimate it to weigh about 300lbs.
    So it needed something substantial and what you see in the pictures
    and the drawings, is what I came up with.
    A small car jack for ten bucks, picked up at the scrap yard, 4 heavy
    duty swivel casters and 6 butt hinges, nuts and bolts of course.
    The rest is basically scrap lumber I already had.
    I have not given any dimensions in the drawings, not to be secretive
    about it, but anyone who would like to copy it, would have to adapt
    it to their own bench dimension anyway.
  • wardprobst
    • 681
    • Wichita Falls, TX, USA.
    • Craftsman 22811
    That's a real clever design, I'm impressed~
    DP
    www.wardprobst.com
      Very nice setup, big tim!
      I've recently "re-purposed" a cabinet originally designed tio be fixed against the wall. It now stands free, similar to yours. Like you, I have a small shop in which mobility is necessary.
      I probably won't copy you lift idea, as I have my own thing. I really give you high marks for ingenuity, though. That thing is really clever!
      I probably will steal the dust panel idea, though. I haven't decided whether to put doors on the front, or build shelves like yours. Right now I've got my mortiser stored there, which requires more than the available height.
      Cool idea on the hose-wrapped bench dogs, too. Would this be where the Canadian term "Hoser" was derived?
      • DUD
        • 3309
        • Jonesboro, Arkansas, USA.
        Very nice, I like the concept, and space is always a problem. Bill
          That is very nice. I like the pull out shelf.
          • ChrisD
            • 881
            • CHICAGO, IL, USA.
            Big Tim, you definitely turned that into a car jack of all trades! Very cool idea.
            I have only needed to move my workbench once (but will be moving it again soon). I improvised a couple of 'skateboards', each made using a piece of 2x6 and four puny little casters. IT TOTALLY SUCKED.
            Thanks for sharing your designs!
            Chris
              What everyone else said. I like it. Great idea! I might use that in the future when I set up my shop at retirement - if I remember it!
              • Turaj
                • 1019
                • Toronto, Ontario, Canada.
                • BT3000 (1998)
                Great design Tim (and so simple!). My next workbench (the real one) has to be mobile and I may have to steal yours (the idea not the bench)
                Turaj (in Toronto)
                • thrytis
                  • 552
                  • Concord, NC, USA.
                  • Delta Unisaw
                  Great idea for the mobile base! I've been trying to figure out how to make a workbench mobile yet have it completely off castors when stationary. I've been focusing on a motor cycle style lift mechanism, but this is so much simpler to do. When i finally get around to building a bench, i think i'll use your mechanism as the basis for my design.
                  Eric
                    Great idea, Tim!
                    • lcm1947
                      • 1490
                      • Austin, Texas
                      • BT 3100-1
                      Now that's a work bench and a half. The lift idea is amazing . I too am impressed. Nice job Pappy. I just got through looking at your site for the first time. Man! you do some nice work Pappy. Darn!!!
                        Now that was thinking outside the box! Great idea.
                        • Popeye
                          • 1848
                          • Woodbine, Ga
                          • Grizzly 1023SL
                          SLICK, really darned slick. Pat
                            Very nice!
                            • Wood_workur
                              • 1914
                              • Ohio
                              • Ryobi bt3100-1
                              I like you mobile base, and the slide out shelf.
                              Alex
