I use a ZCTP almost all the time. I ruined a set of belts when an off-cut fell into them plus I like not having to change the throat plate to avoid chip-out. I do not like the extra dust on the top of the saw when using a ZCTP, however. I tried extra holes in the ZCTP away from the blade but that seemed to make no difference. I had an old ZCTP in the saw until today so I tried drilling a large (35mm) hole in the back of the blade slot and that seemed to help but I noticed the trailing edge of the blade was covered by my big hole only part of the time (the blade position changes with the height of the blade). Today I came up with an improved design that passed a couple of tests.
I noticed the slot in the stock throat plate was just over 1/2 inch wide. I measured the position of the back of the blade (trailing edge I called it above) emerged from the throat plate at up to 6 1/2 inches up from the back edge of the ZCTP. With that in mind, I cut a 1/2 inch wide slot in a new ZCTP (I make them of pre-finished laminated hardwood flooring scraps that are about 3/8 of an inch thick) on my router table that is centered on the blade slot (I used an old ZCTP to position the fence of my router table) and starts 1/2 of an inch from the back edge of the ZCTP and ends 6 1/2 inches from the back edge. The front of the blade cut it's own grove in the portion of the ZCTP closest to the operator - I call it the front of the ZCTP. I now have a ZCTP with the front cutting part of the blade truly Zero Clearance but the back edge of the blade (and the splitter) in a 1/2 inch wide slot.
To test this design, I ripped a melamine covered particle board scrap using my normal LU84 blade (50 tooth, mainly ATB grind but with 10 flat topped ripping teeth). It will chip melamine pretty badly unless I use a ZCTP. Then the cut is almost chip free. With my modified design, a nice almost chip free cut. The wide slot did not hurt that function. Next I cleaned off the top of the saw and did a few rips including some MDF. Very little dust on the top of the saw - about like using the stock throat plate. Next I ripped through a short piece of 2x4 that was about 3 inches wide. These wide rips would put the most dust on the top of the saw. Again, very little dust emerged with the new ZCTP. I am very happy with this performance.
I do not know if 1/2 inches wide for the back of the slot is optimum. I was going to start small and work up and got lazy and just tried 1/2 inch. I am using a 1hp DC with two ports under the saw, one is on the normal BT3100 dust collection opening and I put another 2 1/2 inch port up under the saw so I wouldn't have to tip it up for cleaning as often. I have the back of the saw blocked off with one of Jim Frye's articulating plates and I put magnet pieces over the other large openings. I thus have pretty good airflow under the saw but was still getting significant dust on top until I put in a modifed ZCTP.
This idea is not mine, somebody else commented on the previously but I did not catch dimensions for the oversized opening. I think I thus may be providing a few specifics to refine somebody else's good idea.
LCHIEN
