Spruce and Sandeply – Another base option
  • staff
    • Jun 2014
    • 73
    There are several good mobile bases for the BT in the plans section but none were exactly what I wanted. This base is designed for cut down extension rails (50-60+ inches rip capacity), less weight in the structure, and a different method of attachment for the rails. The rails slide on pieces of 1/8 inch thick flat stock and are clamped in place by knobs that go into tapped holes in the flat stock. This allows easy repositioning. This base also features a router in the extension table. It rolls on a mobile tool base from Harbor Freight which is integrated into the torsion box base. Construction is glue and screwed joints with nothing more complicated than a dado required. There is plenty of space for drawers for storage (five are shown but you can see there is space for more).
