BT3000 Jig Saw Mount
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This setup uses an old Jig Saw and a 3/4” thick plywood router mounting plate.
    The mounting plate is cut and relieved to hold the base of the jig saw against the
    underside of the BT3K accessory table. Since this was a spare jigsaw, it is
    permanently mounted in the plate with adhesive. Different saws will require different
    cutting and relieving and could conceivably be mounted with screws and nuts to
    facilitate removal from the plate. Thus, there are no drawings with this file, just some
    pictures to show the finished product. I used a curved sink tail pipe screwed to the
    mounting plate to provide a shop vac hose connection point. I used masking tape to
    enclose the space between the saw and the pipe to further enhance the dust pickup.
    Note the steel washers epoxied to the mounting plate to provide crush protection when
    the jig is bolted to the BT3K table.
    Jim Frye
    The Nut in the Cellar.
