Cove Cutting Jigs for the BT3000
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This article covers the construction and use of a set of jigs to create cove moldings
    on the BT3000. Making cove moldings on a table saw is an old technique and is easily
    done on the BT3K. This technique can be used to cut a cove of almost any dimension up
    to 3 9/16” deep and up to 9 1/2” wide, although those dimensions are probably way beyond
    the realm of practicality. The cove cut on a table saw is not a true circular form, but rather
    an ellipse of nearly circular shape. The deeper and narrower the cove, the more elliptical
    it’s shape will be. Typical coves are usually 4 to 5 times wider than they are deep and this
    curve looks circular to the eye. In reality, this setup will cut almost any size cove that you
    would need for any furniture project. This method has been written up in many books on
    table saws, books on table saw jigs, and in many magazines over the years, so this is
    nothing new. The information may not be readily available to BT3K users and so is
    presented here with an orientation toward doing it on the BT3K.
    Jim Frye
    The Nut in the Cellar.
