Ryobi BT3000 Router Fence Construction Notes
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This router fence is designed for use with the Ryobi BT3000 rip fence. It is essentially a hollow wooden box that attaches to the top T-slots of the rip fence and encloses the router bit that is mounted in the BT3K accessory table. The fence has a chip collection port at the right end of the fence to be used with a 2 1/2” diameter shop vac hose. The fence also has an adjustable guard for the bit opening, a 6” high fence for handling vertical work pieces and for clamping hold downs, and threaded inserts in the fence face for the attachment of accessory jigs like a pivot pin or a jointer fence.
    The rip fence remains usable with this router fence mounted.
    Jim Frye
    The Nut in the Cellar.
