This project came about because of my lack of cabinet space and my growing dissatisfaction with out-feed rollers. The top I used was 1 1/4” particleboard with a plastic laminate top. I chose this mostly because I had it on hand. You can use whatever you have and adjust the dimensions accordingly. Also, when the slab was poured in the
building I am using for a shop they were not very good about leveling it. Because of this I built my cabinet about 1/4” lower than the top of my saw and used Kitchen cabinet type leveling legs to bring it even and level with the saw top. The top of my saw measures 37 1/4” from the ground and sitting flat the height of the cabinet is 37” even. I bought the leg
levelers from The Woodworkers Store, Part # 20826. They come four to a set at $9.95 a set. They measure 4” at their shortest and give you 7/8” of adjustment. Phone # is 1-800-279-4441.
