High Fence for Dado and Panel Raising
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This fence was built for supporting a sacrificial face attached to the rip fence for
    dado and rabbit work. By making the right side face tall also, this fence can be used to
    make raised panels by setting the fence on the left side of the blade. The fence is 24”
    long, but could be longer to provide more support beyond the blade. The fence is 6” tall
    and has four partitions to hold the faces parallel. This fence is held on the rip fence by
    two strips of wood that ride in the T-slots in both sides of the rip fence. This one was
    made from 3/4” hard maple, but plywood would be more stable, especially if it wasn’t
    finished like this one is. The fence was built up on the rip fence to ensure that it was
    square with the fence. Be sure to wax the rip fence before doing any glue so that the
    dried glue won’t stick to the aluminum and to make it easier to remove the high fence
    later. There are no drawings for this jig. It was built following the basic design of the
    tenon jig I designed. See the pictures below for the orientation of the parts.
    Jim Frye
    The Nut in the Cellar.
