Drill Powered Drum Sander for BT3000
  • Jim Frye
    • 1362
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This setup is based on an old Portalign drill accessory and a 3/4” plywood router
    mounting plate. The Portalign is a useful little gadget, but adding the router plate gave
    it added stability. I didn’t have a drill press when I put this together, so this rig allowed
    me to sand curves in wood with better control than hand sanding. I routed a 1/2” deep
    recess in the under side of the plate to receive the Portalign base and used the two
    mounting holes in the base to secure it to the plate with flat head machine screws and
    nuts. Using the Portalign’s depth stop as a height adjuster, you can set the height of
    the sanding drum relative to the BT3K table. Note the four steel washers epoxied to
    the underside of the mounting plate to provide crush protection when the plate is bolted
    to the BT3K table. I believe the Portalign is no longer marketed, but Wolfcraft makes a
    modified version of a drill guide.
    Jim Frye
    The Nut in the Cellar.
