BT3000 Belt Replacement and Shim Adjustment Instructions
  • Jim Frye
    • 1359
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    The following document is transcribed from the sheet that Ryobi Technical Support sends out if you request belt-changing instructions. It also contains information about adjusting the setscrews that hold the guide holder shims in proper alignment and instructions for taking the motor out. Ed Ellickson (see his article elsewhere on this site) expanded on this article to make belt changing even easier. Ed’s article should accompany this one for anyone planning to change their own drive belts on the BT3000.
    Jim Frye
    The Nut in the Cellar.
