A BT3000 Maintenance Check List
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    This document discusses the steps a BT3000 user could use to perform periodic
    maintenance in an effort to extend the life of the saw. The question of how often to
    perform this type of maintenance is dependent on the amount of usage. As a general
    rule of thumb, any time something on the saw does not perform in a normal fashion
    would be a good time to perform this entire maintenance process. Even if you are using
    the saw with an operating dust collection device of some type attached, you might as
    well perform the entire process, rather than just checking what you think may be wrong.
    If you haven’ t been using a dust collection device with this saw, you will have to
    perform this maintenance and cleaning a lot more often. Running this saw with some
    form of dust collection attached is one of the best things you can do to prevent
    premature failure of the components of this machine. If your machine requires any
    repair or maintenance that you do not feel you can do, contact Ryobi Technical Support
    for assistance in locating a repair center closest to you.
    Jim Frye
    The Nut in the Cellar.
